Dealer has sent a puma to BMW for help. They have replaced the AUX kit and reprogrammed the CIP as if it were a new install (so they tell me).
Anyone know of any issues when an AUX port is used with Logic 7?? :help: |
Absolutely no issues with any E60/E61/E63/E64 configuration. Bad, bad install. Some reports of reversed wiring instructions early on, but had not seen any reports recently.
Did they switch the position of the wires going into the connector, as called for on the bottom of page 6 of the instructions?
[snapback]173180[/snapback] I said "not the plug", you need to phisically disconnect the wires from the kit as it is supplied as standard, and rewire as per section 6 in the insructions :bash: :badbad: Anyway, they owe me a phone call, in the morning after talking with BMW :think: PS they have no way of accessing the internet, cos I suggested they look at this forum for advice :whistle: |
[snapback]173095[/snapback] I have it on mine. |
[snapback]173180[/snapback] They have booked the car in again on Friday next week. The feedback from BMW was something along the lines of check fuses, and PINOUTS. Told them to check the pinouts they said they had...if they had why are they now so confident that they can fix it in 1.5Hrs!!!! :bash: He sounded embarrased on the phone, I will make full use of the hospitality area in the dealership again...my waistline is getting bigger :thumbsdown: |
Same problem here! Logic 7, aux input installed... no sound. Of course sevice was closed when I picked the car up.... Have to go back next week!
Originally Posted by mixterk' date='Sep 22 2005, 03:53 PM
[quote name='stream' date='Sep 21 2005, 04:59 PM']Did they switch the position of the wires going into the connector, as called for on the bottom of page 6 of the instructions?
[snapback]173180[/snapback] They have booked the car in again on Friday next week. The feedback from BMW was something along the lines of check fuses, and PINOUTS. Told them to check the pinouts they said they had...if they had why are they now so confident that they can fix it in 1.5Hrs!!!! :bash: He sounded embarrased on the phone, I will make full use of the hospitality area in the dealership again...my waistline is getting bigger :thumbsdown: [snapback]173566[/snapback] [/quote]Hi all, said I would let you know when it was fixed...well miracles do happen, I can catagorically tell you that it was the pinouts as detailed in section 6 of the instruction guide readily available on this forum. In the end I had to stand over them and make sure they reterminated the lead as per the directions. So please remember this, if your AUX In doesnt work after its been programmed into the Idrive (you will know when this is done correctly as the AUX In option will appear on screen) it is 99% sure to be the fact that they havnt followed the retermination of the pinouts. Now its done it sounds great, Im using my IPAQ 3150 and Conduit Pocket player software and its sounds awsome. :thumbsup: :thumbsup: Hope this helps anyone not to go thro the crap Ive had to... :bash: :bash: |
Originally Posted by mixterk' date='Sep 30 2005, 11:31 AM
[quote name='mixterk' date='Sep 22 2005, 03:53 PM'][quote name='stream' date='Sep 21 2005, 04:59 PM']Did they switch the position of the wires going into the connector, as called for on the bottom of page 6 of the instructions?
[snapback]173180[/snapback] They have booked the car in again on Friday next week. The feedback from BMW was something along the lines of check fuses, and PINOUTS. Told them to check the pinouts they said they had...if they had why are they now so confident that they can fix it in 1.5Hrs!!!! :bash: He sounded embarrased on the phone, I will make full use of the hospitality area in the dealership again...my waistline is getting bigger :thumbsdown: [snapback]173566[/snapback] [/quote]Hi all, said I would let you know when it was fixed...well miracles do happen, I can catagorically tell you that it was the pinouts as detailed in section 6 of the instruction guide readily available on this forum. In the end I had to stand over them and make sure they reterminated the lead as per the directions. So please remember this, if your AUX In doesnt work after its been programmed into the Idrive (you will know when this is done correctly as the AUX In option will appear on screen) it is 99% sure to be the fact that they havnt followed the retermination of the pinouts. Now its done it sounds great, Im using my IPAQ 3150 and Conduit Pocket player software and its sounds awsome. :thumbsup: :thumbsup: Hope this helps anyone not to go thro the crap Ive had to... :bash: :bash: [snapback]177437[/snapback] [/quote]Finally! :clap: :clap: |
