NEED XI HELP PLEASE
My Ride: 2008 535Xi
Platinum Metalic Gray, Black Dakota Comfort pkg, Cold weather pkg.
While I have two sets of tire for my 19" wheels I can decide what to send back? I have a set of 245/40/19 f and 275/35/19 r.
and a set of 245/35/19 f 285/30/19 r. the recommended size. The first set is almost 1 inch bigger, and it is not the rubbing possibility that bothers me as if this happens I could live with it.
THE PROBLEM IS - Will a 1 inch difference mess up the AWD? Can you increase the overall diameter without screwing up the AWD? Any expertise in this matter would be greatly appreciated.
Also looking for a strut bar for a 2008 535xi thanks
Use this tire size calculator to determine http://www.miata.net/garage/tirecalc.html the rolling radius for the tire sizes you've mentioned. I think the 245/40x19" will be too tall for the xi - especially since the 245/40x18 is the stock tire size for the sport/performance tire set up. And I'm sure a 1" difference in diameter ( front to back ) will likely raise heck with lots of things including ABS and Stability systems that measure differences in wheel rotation and slip. Then there's the issue of fit too!
My Ride: 2008 535Xi
Thanks
My Ride: 2006 titanium silver metallic
Like new 41k
Cold Weather Package
It will effect the speedo but i think if all 4 corners are near the same height you should be fine. I think it will raise your car up a bit, I would stick with the recommended sizes, keep it as close to stock tire height as possible.
