Need Quad Conversion Help
Originally Posted by nigxdoof' post='716519' date='Nov 9 2008, 07:31 PM
Actually, Anthony517's setup is the one you want,
http://forums.e60.net/index.php?showtopic=49606&hl=
Take a look at his thread.
And the tips, I got from Evsmotors.com. Call up ted and ask for the M6 oval tips. He'll let you know what's up. Or you can go 2 AAA motor in cali. I know a lot of guys here went to them for exhaust work.
All I have is the MAGNAFLOW MUFFLER WITH BUILT IN X PIPE which then runs two pipes out to the QUAD tips and I am satisfied with the sound. If you want a louder noise than take out the FRONT resonator as well. Hope this helps.
Thanks for your help!
Originally Posted by AlexFW' post='716990' date='Nov 10 2008, 07:13 AM
I see you are using one of my pictures.
I suggest to install all mufflers you can, if you want the car confortable: I have 5 of them:
Attachment 64372
and it is quite confortable, but if the car had more space I would get an other muffler more.
Silence is never enough
- imho
Attachment 64372
Do you have any sound clips? 5 mufflers seems a little excessive no? so you're using mufflers in place of the resonators?
Originally Posted by Bimmer32' post='716572' date='Nov 9 2008, 06:15 PM
2.5 OD might be too big for your setup. Try 2 to 2.25 only. The more mufler you use, the less loud and less droning you will get.
i've helped a handful of ppl with their quad exhaust needs, hit me up and i'll see what i can do for you.
im confused again... is the resonator also called the "Center muffler"? Can someone pin-point on this diagram where the resonators are located? 1 and 2 are the catalytic converters....
Sorry im a complete newb when it comes to modding and mechanics. Thanks!
![](http://www.realoem.com/bmw/diagrams/h/g/251.png)
