need help with wheel fitment and lowering
My Ride: 2010 BMW 550i m sport lci
so im plan on buying new wheels and coilovers for my 2010 550i w/sport pkg 20" staggered 20x10 25mm offset in rear and 20x9 20mm for the front 275/30/20 in rear and 245/35/20 in front *concave wheels* at the same time im gonna lower it on coilover but don't want to rub or roll fender am I going to be ok with this set up? can I even go 20x11 for a more aggressive look? thanx so much going crazy trying to figure things out
My Ride: 2006 550i
Hello again, if you are planning on going 20s and lowering on coils you need to stick to the correct tire specs. 245/30 and 295/25 rubberbands if your willing to do it? If you dont want rubbing issues.
Here is a pic of a buds car from Washington. on those specs. I believe ideally you should be at 20mm all around? GL
