Need Help Tire Sizes for OEM M6 wheels!
My Ride: 2004 530i
AFAIK, there is only one size (M6 offset) for the OEM M167 rims. To answer your original question, yes. You'll be fine and get 275 for the rear (that's what I have).
Also, you might want to add spacers to improve the look (wheel sits flush with the rear fender). This is only if you want a wider stance, spacers are not required for normal installation. For tire choices, I'd suggest getting the Vredestein, they are great, perform well in wet/dry conditions and look wider. GL
the M5 offsets will work fine without spacers, but most members decide to put on spacers just to get a more aggressive look and stance in the rear by widening the stance a bit. with the M6 offsets, you would have that stance already without spacers.
Originally Posted by Rizbel' post='943776' date='Jul 16 2009, 05:01 AM
M5 offset will work but you'll need spacers. I have M5 offset that's why I have a pair of 12mm spacers at the rear.
Originally Posted by Masatus' post='945297' date='Jul 17 2009, 06:47 PM
Why M5 wheels need spacers?
My Ride: 2004 530i
Can someone please recommend me some tire brands? I am located in Southern California (hope that give you an idea about the weather). I do not want something that is very expensive nor very cheaper..
Originally Posted by vincentkpham' post='943686' date='Jul 16 2009, 02:22 AM
Either sizes will work, but i would go with the 275 in the rear since the M6 offset is more aggressive. Vince.
245/35/19 and 275/30/19 is the best option. If anyone needs wheels and tires let me know. I probably can beat other's prices or at least match. Just bought my E60 530I nd loving it.
Beemer
33
01-14-2019 05:13 AM
tcast305
06-10-2004 05:50 AM
