need help on muffler
Old 12-22-2008, 04:06 PM
suthurnbimmur's Avatar
My Ride: 2004 BMW 545i
Thumbs up
I wanted to go the inexpensive route to change my muffler/exhaust. I do not have the $$$ to get a whole new exhaust and would like to change the stock muffler to a universal Mangaflow. Can some one help with the measurements?? Whats the size of the inlet? and would this enhance the sound a bit? is this a good idea? Going more for a better sound and the look of bigger tips in the back. Appreciate your feedback, thanks.
Old 12-22-2008, 05:26 PM
magnaflows give a sort of deeper rumbling sound. the inlet should be 2.25" - 2.5" wide. many have gone with just replacing the muffler, others with changing the piping as well and taking out a resonator(s) and others have gone with a quad exhaust set-up. for a single side, it usually comes down between the 14816 and 14862. PM sent. let me know if I can help with anything
Old 12-22-2008, 05:34 PM
ktlocklear's Avatar
My Ride: '06 550i '84 Nissan S12 Turbo
dumb question...but what do you do with the vac line that hooks up to that actuator on one of the outlets on the stock muffler....just plug it?
Old 12-23-2008, 04:58 AM
Thanks NerWeezy!! Def good Ideas............About taking out the resonator, would the sound be too loud? I just to enhance the sound and still look like a Luxury Sports car, ya know. I think I might go with just changing out the muffler and if I still want it louder, will remove the resonator.
What about the Vac Line that Ktlocklear is talking about, is that gonna be an issue? What do you do with that line? Thanks again guys......
Old 12-23-2008, 05:01 AM
bespoke1's Avatar
My Ride:
I'm considering Magnaflow as well. What is the difference between the 14862 and the 14816??
Old 12-23-2008, 08:27 AM
TAJARO's Avatar
My Ride: 2007 550i, Mystic Blue over Auburn, 6-Manual, Sports, Premium, Cold Weather, Logic 7, Nav, Sirius, MTec Front & Sides with M5 rear apron, VIS Penta carbon fiber vented hood, OEM M166s, (or Style 101M with winter 19 Blizzaks), BMW Blue Calipers, Custom Quad Exhaust and M5 side grills, trunk finisher and spoiler. Rogue Octane SSK/WSR and Zeckhausen CDV, BMW illuminated shift knob, Delivered 4/26/06 - Ordered 3/18/06 from Otto's (the Best) BMW Dealership.
Another option is the driver's side M5 exhaust...
http://forums.e60.net/index.php?showtopic=...mp;#entry750379
Good luck. It's teh ebst mod you'll do I bet-
Old 12-23-2008, 08:30 AM
TAJARO's Avatar
The vac line just opens the other side of the muffler at certain RPM. Below that point it's to create more bck pressure which some think helps torque and/or scavenging for fuel economy and emissions. Just unplug it, block the line and it's fine- no codes thrown and I've been in to the dealer for service with no comments/issues.
Old 12-23-2008, 10:16 AM
ktlocklear's Avatar
Any gain's keeping it open all the time with the stock muff...or will it hurt performance?
Old 12-23-2008, 10:37 AM
545felix's Avatar
My Ride: 05 545/6
The problem is you can't just disconnect and plug it, that would leave the valve in the closed position. You need to have a muffler shop spot weld the valve open and then you can just leave the line plugged in. It shouldn't cost $20 and will take less than 5 minutes. two little zaps of the welding torch.
Forcing it open gives an ever so slightly deeper rumble, but don't expect an aftermarket exhaust note.
Old 12-23-2008, 11:01 AM
Ricracing's Avatar
Hope my link helps you suthurnbimmur
Link here.
Quick Reply: need help on muffler
