need help to modification LCI to sportautomatic shift steering wheel
hello bmw-friends ,
my name ist bert from germany . i drive a 530d automatic year june 2007.
for a few month i installed the sport-automatic Gear shifter and now i want to
complete it with the sportautomatic shift steering wheel.
i dont know how to do ... somebody says i just only have to intall two
wires from the steering wheel to the gearbox . can i use this bmw-part :
61 31 6 976 396 resp. the cable witch is to use for connect steering wheel ang gearbox ?
Now my question is what have i to do , is here in the forum a DIY or a topic.
thank you for help an have a nice day
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
SAT Retrofit Thread
It's a long thread, but covers everything required to install the SAT shifter (which you appear to have already done) and add the paddle-shifter steering wheel. Both myself and NavarrOne have successfully completed the complete retrofits with the paddle-shifters. Heck, I even added the heated m-sport wheel from 2009+ models while I was at it, because it gets COLD here in Winterpeg!
Hello Wpg550 ,
thank you for the link ... very good link .
Sorry but my english is not so good but the most i have understud.
What means the SIB 25 03 07 - Paddle Shifter Diagnosis.pdf , my car was build in may 2007 ? have i got to do some elekrtik modifications bevor intall the shifter-wheel like shown in this pdf ?
what means - SZL - ?
what part did you accessorily to motify to the heated function ?
(because i can get a shifter-wheel with headetfunktion)
part number :
- 61 31 6 947 787
- 61 31 6 947 774
- 61 31 6 927 092
Thank you ...
part number :
- 61 31 6 947 787
- 61 31 6 947 774
- 61 31 6 927 092
Thank you ...
Bert,
The SIB is a service bulletin that provides updated information on the correct wiring of the SZL (steering column switch cluster/module) to the rest of the car, as the information in the BMW wiring diagrams provided to dealers had an error. A PDF of the service bulletin is included in the thread.
To get the heated wheel functionality, I had to add a new:
I don't have the part numbers handy, but a quick search on realoem.com will turn up the appropriate numbers with the heating functionality.
- steering wheel adjuster switch - the switch unit that allows you to move the steering wheel also houses the heater on/off switch, so I had to replace with one that had the heater button
- spring coil pack - connection from the steering wheel buttons/wiring to the steering column SZL unit. My original car did not have heated wheel, so the spring coil needed to be changed to one that had the extra connections for the heater
okey Wpg550, i try to get the SIB in German Language ... thats better for me ;-)
the parts for heated wheel modifikation ( i think thats all parts i need)
61316976395 spring coil pack
61316976397 Wiring
61316947774 Switch
32346774461 wheel
61316947774 plastic
the steering wheel adjuster switch is this with "on" light ? - i have never bevore seen this
61316976397 Wiring
61316947774 Switch
32346774461 wheel
61316947774 plastic
Bert,
You need part number 61316947788 with both the steering wheel adjustment and heater switch on it. It will fit into the existing space where your current switch is (which probably only has the adjuster?).
It's the middle one in this link.
Wpg550 , i have no elec. steering wheel adjustment !
so that i think the switch 3 (in your link) is the right.
do you know were i have to connect the swich ?
(modul/box)
61316976397 Wiring - i think one cable in the switch and the other ?
(modul/box)
Bert,
You should hunt down an online WDS (wiring diagram) to see where the switches connect. All my work was done by the dealer, so I don't know where the connections are.
Good luck!
Good luck!
61316976397 Wiring
61316947774 Switch
32346774461 wheel
61316947774 plastic
61316976397 Wiring
61316947774 Switch
32346774461 wheel
61316947774 plastic
wgp this part you didn need because you must have LDW - right ?
I did need this part (actually the replacement part 61319204504), but didn't include it earlier in the thread as I needed it only for the addition of the heating function, not for the SAT paddles. This is the SZL unit referred to earlier.
