Need help finding correct fuse box connector terminal
My Ride: E60 520i 2004
![Question](https://5series.net/forums/images/icons/icon5.gif)
Hi people,
I'm currently trying to install a 12v socket in the boot of my E60 (08-2004), but ran into a small hickup.
Before I started, I was informed to add the plus wire to pin 9 of the fuse box connector for power using fuse 82. After opening up said connector, I see pin 9 is already in use. There's a red wire with dark blue stripe installed.
Should I use a different pin all together? Should I solder my plus wire to the red/blue one?
What's red/blue normally used for?
Thanks for any info!
John
John
Brendan412
10-22-2015 04:19 AM
PelicanParts.com
08-14-2015 10:15 AM
