Need help: Dension GW500 install (again....)
My Ride: E60 530d 218ps
Basically my car has CDC, Business Nav with MP3 playback enabled
I bought a 2nd hand GW500 unit from a fellow forum member. It has 6 DIP switches and has the 2 ports: CAR SIDE and CDC Side.
So far have managed to tap power supply from the CDC and followed connection "2a" as per the instructions. DIP switches are set: 1 & 2 on, and 3 - 6 off. The LED lights up and I can switch the CDC on & off using the Dension switch.
However when I select CD from the iDrive only the single disc CD is selectable, and options CD1 - CD6 are greyed out. When I connect my iPhone it acknowledges the connection and asks to activate the airplane mode. I still can't access the iPod or files from the USB key. Both my iPod touch and iPhone 2G are not charged by the gateway
I have tried flashing the Gateway to ver 2.15 but has been unsucessful. The USB key lights for a few seconds, but after leaving it for more than 10 minutes, the rom file is still there - meaning update didn't take place.
What am I doing wrong? Have tried searching the forum but can't seem to find a relevant post.
Thanking all in advance....
My Ride: 05 545/6
version 2.15 is incorrect firmware- that is for D2B versions- you need the MOST version of the firmware. that is currently at 2.101.
i don't think either of those ipods can be charged with the stock cable. I would check two things, one make sure you are actually getting switched power to the unit, and that the fiber connections are correct (they should be if the changer works, but i think that setting just bridges two of the fibers- so i'd check the out from the car side plug and in on the output from the dension, since those are the two that involve output from the gw500.
also- the switch takes 15-20 seconds to fully take, it's not an immediate response.
hth
Thanks for the quick reply Felix,
I checked the connections again, and they all seem to be fine. All the red lights seem to be shining in the right direction anyway...
Had a look at the website for Dension and it says the latest firware for MOST is 2.15. The D2B version's latest firmware is 2.101
Do you guys remember if the DIP switches for your setup are set the same as mine? Anything else I should be looking at?
I thought this was going to be one of the easier mods.... maybe I'm just unlucky!
My Ride: 05 545/6
my dip switches are set up like the 2a- 1,2 on, the rest off.
WAIT. just re-read your original post. you have BUSINESS nav, not PRO nav. the smaller screen right, not the one in my signature? Flip the first dip switch down and try that. The m-ask supposedly does not support text on the cd changer interface, although i've seen people on here that have it. might have been a running change or an LCI update.
My Ride: 05 545/6
Originally Posted by 545felix' post='741401' date='Dec 9 2008, 01:19 PM
you're right on the firmware, i got my wires crossed while I was posting. mine took two tries to take the update.
[topic="65287"]M-ASK Business HU & TEXT with Dension's Gateway 500[/topic]
Originally Posted by 545felix' post='741427' date='Dec 9 2008, 06:47 PM
found the post about the business radio and the text. you'll need a trip to the dealer for ipod coding if you want the text. for now you can just flip switch 1 down, it will work but you won't have text.
I wish I had read about the Business units not being capable of displaying text; just had the car coded for CDC last week!! Looks like another trip to the dealer. Can an independent autoshop with autologic system do the coding, possibly for less money?
My Ride: 05 545/6
Originally Posted by 666bxg' post='741489' date='Dec 9 2008, 02:51 PM
Felix, flipping the switch worked for me
shervinj
04-23-2015 05:42 AM
turbogate
04-11-2015 05:02 PM
