Need help with 20" wheel front/rear offsets
Old 12-14-2008, 08:26 AM
DKNewYork's Avatar
Mine only rub when I get 2 or more people in the backseat when I hit a pothole or bump. Offset is unknown and I'm running 20x8.5 fr and 20x10.5 rear. 275/30 zr 20 in the rear and 245/35 zr 20 in the front. 3" lip and 5" lip.
Old 12-14-2008, 08:45 AM
nigxdoof's Avatar
I have 245/35/20 and 285/30/20 but they are Falken 452's, which are known to be a slimmer than other tires. So their 285 is close to other companie's 275.
As for rubbing and offset, I was having issues with Koni Struts and Eibach pro kit springs. That was the front though. Once I changed it to coilover's and adjusted the height accordingly and rolled the rear fenders, no more rubbing.
I believe the Radenergie's also didn't have the offset indicated, but was fitted for e60's.
What wheels do you plan to get now?!?!
Old 12-14-2008, 09:43 AM
mrfva's Avatar
My Ride: .
Model Year: .
Who said I was getting wheels, I was just asking about 20" offsets
Old 12-14-2008, 10:09 AM
nigxdoof's Avatar
That's the only reason why you would ask... not like your wheels will change offsets..
I know, i know.
Old 12-14-2008, 11:39 AM
tbal's Avatar
My Ride: See sig :)
anyone running 20x11s?
Old 12-14-2008, 03:08 PM
KnIgHtCoM's Avatar
These are my wheel offsets:
20 X 9.0 +25A
20 X 10.0 +19O
I was running Toyo T1R 285/25/20 and 245/30/20 on my original set of tires and had absolutely no rubbing. I'm using a 15mm spacer on the front because the inside of my wheels were rubbing the inside of my shock on hard turns, since my car is so slammed. I also wanted to push the wheels out more flush with the fender.
I'm now running Michelin Pilot Sport A/S 295/25/20 in the rears. I had to do some major modification to get them to fit. I cut off some of the plastic liner and rolled the whole fender on the quarter panel. I also shaved off some of the metal where the quarter panel meets the rear bumper. There's still a little bit of rubbing under full compression, but I'm using some rubber bump stops to prevent that from happening. Overall, I'm happy with the new tires. The ride is a tad bumpier on uneven streets due to the bump stops, but that's me just being nitpicky.
The Michelin's look sick though. No more pulled drifter look tires! I hope my experience will be helpful in your decision.
Old 12-14-2008, 03:11 PM
vegastrashed's Avatar
Ryan,
You could have shaved off 3mm from the offset to help the tires fit.
Old 12-14-2008, 03:12 PM
KnIgHtCoM's Avatar
Yeah, but the poke looks sexy. I'll post some pics when I get the car washed.
Old 12-14-2008, 03:38 PM
SoCalBimmer's Avatar
My Ride: 2004 530i
I don't know my offsets. Got my rims from Ace
Old 12-14-2008, 03:47 PM
KnIgHtCoM's Avatar
iForged doesn't make their offsets public, so you won't get any help from those guys.
Quick Reply: Need help with 20" wheel front/rear offsets
