My new CCC has an AUX input and CD changer...
My Ride: e60
Model Year: 2005
My original CCC was programmed just for a CD changer, but this new CCC I bought has an option for an AUX input. How would I be able to use this? Would it be as simple as buying some sort of adapter?
My Ride: e60
Model Year: 2005
Now heres the real question. Could I do an ipod interface as opposed to the aux input?? I dont recall seeing any blank jacks on the back of the CCC that ive got nothing plugged into, unless I overlooked something. Where does the Ipod interface ultimately connect to the system?
Engine: N54
My Ride: e60
Model Year: 2005
My original setup is cd changer and sat radio. This new CCC is programmed for a cd changer and an aux input. I'm assuming the sat radio is an external unit. How does that connect to the system? I dont care to have satellite radio. Could I use the input the satellite is on for the ipod input, or whatever input the new CCC had setup for the aux input? Or is the only connection that would work with an ipod is being used by the changer?
Each module such as SAT radio, CD Changer and/or iPod interface are connected via MOST fiber optic link. The SAT module located in the trunk (behind the left panel) so if you feel it'll be OK to stick your iPod back there then you can try it that way.
The iPod interface is exclusive use w/ CD Changer so you can only have either one but not both.
Last if you are lucky you can simply plug the iPod interface and it'll just automagically work otherwise you have to get it coded to enable the system knows there's an iPod interface present.
My Ride: e60
Model Year: 2005
Cool... I'm a sound engineer by trade, so Its natural for me to exhaust such an issue lol....
So seeing that the sat radio, CD changer and iPod interface share the same type of connection, in theory I should be able to trade the SAT radio for the iPod interface. If I'm not able to use both the iPod interface, and the CD changer at the same time, then it would be something software related that would prevent me from doing so, meaning its something I should be able to code?? Has there been a case where someone was able to code their CCC to use both iPod and CD changer?
If not, im just trying to understand why iPod and CD changer is mutually exclusive when hardware wise, it should be able to work.
My Ride: 04 545i - Titanium Silver/Black, Sport pkg, Comfort Seats w/ Lumbar, Premium Sound, power rear sunshade, Adaptive Xenon Headlights, Steptronic, Park Distance Control, Fold down rear seats w/ski bag, Aux jack, 6-disk changer, puddle lamps...
Engine: Custom Remus cat-back exhaust w/chrome square tips, K&N Air Filter, Charcoal Filter Removed, Sprint Booster :-), 50/50 mix of 91+100 Octane, EuroRev ECU Remap (coming soon lol), Dinan High-Flow Throttle Body (coming soon...maybe lol)
Interior: Portable Sirius Stilletto 100 w/car kit, Garmin Nuvi 680 mounted below rear-view mirror, LCI-style I-drive knob, Dark Poplar Center Dashboard Trim.
Exterior: E60 forum clings, 5% rear tint, ACS roof spoiler (painted black for distinct look against limo tint), ACS trunk spoiler, ACS add-on front spoiler and rear apron (awaiting installation), "18 Black Staggered BeBeS Style OER (emergency replacement for cracked sport 124 rims), black kidney grill, white accessory lighting (including license and trunk lamps), Angel-eye upgrade, AIB xenon-matched fog lamps, AIB V3's on order, red rear reflectors
Ecause the iPod device
The short answer is you cannot have both the iPod interface and CD changer because the iPod device emulates the CD changer's position on the MOST bus ring. It is not a dedicated device. Plugging in a changer and iPod interface will simply be interpreted as 2 changers. Not designed for 2 changers so it wouldn't know how to control them. If the changers could be identified as CDC1, CDC2, etc, then maybe. But, alas, its only seen as CDC. We see iPod interface. Your car only sees CDC (which is why a prerequisite of adding the iPod interface is coding for CDC).
