Are MRR GT1's compatible with TPMS?
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
You can take the sensors out of your stock wheels and put them into your aftermarket ones if you don't need a winter wheel setup. You can use these TPMS adapters or drill into the inner barrel. I'd recommend purchasing the adapters because drilling into the barrel can cause slow leaks if the sensors are not seated correctly.
kcrokin
09-03-2015 10:38 AM
Bank$hot530
07-12-2015 04:36 PM
