Mist on Eyebrow and LED Headlight
I just noticed that one of my headlight eyebrow and LED has mist on it. I already checked, there is no crack whatsoever. Any idea how to solve this issue? maybe checking on eyebrow section or something....
The mist in only on eyebrow section of the headlight. Projector section (below) seems clear and fine.
Hope one of you guys had the same issue and solved through this forum.....
Thank s for your help, .....
Hopefully it goes away. If it gets worse where there is water building up, you have to cut it open and hen seal it back up. While you are at it, do the eyebrow mod. Another solution is, get a new headlight.
bestofthebest
03-28-2016 02:47 PM
umnitza
11-25-2015 11:10 AM
Bogdan7
09-23-2015 11:40 AM
