Minimal Mods: B&B Exhaust/Dinan Throttle Body
Old 02-16-2006, 05:37 PM
znod's Avatar
Originally Posted by stream' post='241476' date='Feb 16 2006, 07:13 PM
You'll never know until it happens to your car. Sure, Dinan, and dealers who sell their parts, will tell you--don't worry, you'll be OK, but if you carefully read Dinan's warranty, they've certainly covered themselves. Caveat Emptor!
The installation of Dinan Performance Products and systems may affect the vehicle manufacturer's new car limited warranty. The vehicle manufacturer's new car limited warranty may not apply to modifications to a vehicle or the installation of any performance accessories or components attached to the vehicle which substantially alter the original engineering and/or operating specifications or which result in damage to other original vehicle manufacturer's components.
Right, in principle, the consumer can get stuck. Whether it ever has happened, well, who knows? I don't; that's for sure. Dinan claimed to me that no Dinan customer has been left holding the bag, but, then, would they say otherwise? I don't know that either. Thank you for participating in this thread.
Old 02-16-2006, 05:44 PM
znod's Avatar
Originally Posted by ipse dixit' post='241483' date='Feb 16 2006, 07:16 PM
The decision to repair or replace said parts is at the sole discretion of Dinan and/or the original vehicle manufacturer.
Couldn't the same thing be said of the BMW warranty? Aren't statements convering, in effect, the same ground as the one above needed to avoid claims related to customer error or abuse?
Old 02-16-2006, 08:09 PM
ipse dixit's Avatar
Perhaps.
But the difference, and this is not minor, with the BMW warranty and the discretion it affords BMW to acknowledge a warranty claim is that BMW cannot say, "well, the problem was due to a Dinan mod."
On the other hand, with Dinan's warranty, it could very well say something along the lines of: "Well, the fault that you have is really a BMW issue, not a Dinan modification. The Dinan part worked perfectly; it is the BMW part/spec/design that did not work properly."
You (e.g. disgruntled consumer) then goes to BMW and seek to invoke the BMW warranty because, as far as your concerned and according to Dinan, BMW is the cause of the problem.
Well, you see where this is going, right? BMW will most likely say, "Go pound sand, Znod. Dinan is the problem here."
Old 02-17-2006, 05:18 AM
znod's Avatar
I agree with your point given that what is quoted above is correct operationally, as opposed to only legally. But, operationally, BMW can say "that," and probably get away with it, because no one is going to take the Company to court to try to make things right.
Old 02-17-2006, 09:15 AM
Centurion's Avatar
My Ride: 545i; Manual Shifter
don,
Thanks for the info.
A few things I noted:
The test with mods 'off' was an averaged figure of 11 runs vs. mods 'on' at 6 runs. To be fair, equal number of runs should be compared. When the result we're looking at is at thousandths or hundred thousandths of a second, that can make a significant enough difference. This is easily remedied...grab the first 6 figures you got for mods 'off' and use those in your comparison (ignore, for now, the last 5 you gathered).
Were you in the same program for your Steptronic? If you shifted manually, this may introduce another variable. DSC on/off?
Is there a shop with a dynamometer in your area? This would be the best way to eliminate CIP 20.01.00 from the equation to see how effective your mods are (B&B and Dinan throttle body) unless, of course, 20.01.00 is truly mediating the performance of the motor regardless of air intake and improved back pressure.
I think the most interesting find here is how the unmodded car is quicker from the start but the modded car is just barely quicker to the quarter mile. This leads me to believe the exhaust and throttle body may be more effective at top end. Perhaps a 40-60mph (in 6th gear) test may have more significant results.
Just trying to help. Oh, and by the way, how are you removing and re-installing your B&B? A welder have you?
Old 02-17-2006, 10:21 AM
Don Juan's Avatar
I guess mods inow days are just for looks and sound UNLESS is accompanied by a software upgrade..which I'm waiting for my local performance shop to develop as they tuned my M3s and man it was a huge difference from stock and dinan which i did prior their software upgrade...
Old 02-17-2006, 11:29 AM
znod's Avatar
Actually, my numbering system may not mean much sometimes, but, in this case, the total of 11 runs was about half and half. The data I presented is the average for the 3 best mods-on runs versus the three best mods-off runs. And, I held everything imaginable constant--including all shifting procedures. Check the write up; I think it explains, or certainly implies, that I held everything constant.
I greatly appreciate you helpfulness and willingness to think about the issue at hand. You might have turned the chart upside down though. The modded car seems a bit faster all the way to 50, but some of its apparent "quickerness" is a function of one outlier start for the modded car. And, the unmodded car is faster beyond 60--although the average trap speed is a tad faster for the modded car. Again, these results are partially function of the best modded car run--which is an outlier on several dimensions. I did one run today--with the following main results.
1/4 time......13.787
1/4 speed....102.71
1/8 time........8.940
1/8 speed....81.389
0-60.............5.300
Given these results the 3 best runs for the unmodded car are beginning to make it appear that the mods actually were hurting a tad, but another explanation is possible. Below are the current results for the unmodded car. Among other things, note that the unmodded car's average trap speed now is higher for the 1/4.
.........................Test 9...Test 10....Test 12...Average
1/4 Mile Time.....13.793....13.819....13.787....13.800
1/8 Mile Time.......8.957......8.960.....8.940......8.952
0-100................13.034....13.178....13.078....1 3.097
0-90..................10.569....10.678....10.604.... 10.617
0-80....................8.705.....8.767......8.700.. ....8.724
0-70....................7.013.....7.043......6.982.. ....7.013
0-60....................5.300.....5.322......5.300.. ....5.307
0-50....................4.064.....4.064......4.040.. ....4.056
0-40....................2.972.....2.955......2.946.. ....2.958
0-30....................1.767.....1.776......1.769.. ....1.771
0-20....................1.004.....1.001......1.000.. ....1.002
0-10....................0.364.....0.326......0.325.. ....0.338
1/8 Mile Speed...81.463...81.130....81.389....81.327
1/4 Mile Speed.102.970..102.550..102.710..102.743
Old 02-17-2006, 11:40 AM
znod's Avatar
Please join us on the testing thread. It would be great to have a modded 550i involved.
Old 02-17-2006, 01:15 PM
grogan545's Avatar
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
Originally Posted by Znod' post='241923' date='Feb 17 2006, 03:29 PM
I don't have more time to tidy the chart below up now. I'll fix it better later. I think things on it can be made out.
Hi Penny: You are very welcome.
Yes, but I'm not going to spend the bucks on dyno testing. And, I am extremely satisfied with the abilities of g-meters to measure things relatively at least.
1/4 speed....102.71
1/8 speed....81.389
.........................Test 9.Test 10.Test 12...Avg
1/4 Mile Time.....13.793.13.819..13.787..13.800
1/8 Mile Time.......8.957..8.960....8.940....8.952
0-100................13.034.13.178..13.078..13.097
0-90..................10.569..10.678.10.604..10.617
0-80....................8.705...8.767...8.700....8.7 24
0-70....................7.013...7.043...6.982....7.0 13
0-60....................5.300...5.322...5.300....5.3 07
0-50....................4.064...4.064..4.040....4.05 6
0-40....................2.972...2.955..2.946....2.95 8
0-30....................1.767...1.776..1.769....1.77 1
0-20....................1.004...1.001..1.000....1.00 2
0-10....................0.364...0.326...0.325...0.33 8
1/8 Mile Speed....81.463 81.130 81.389 81.327
1/4 Mile Speed 102.970 102.550 102.710 102.743
I see slow progress in your times.Are you getting better with your runs or is the car getting marginally faster?I also noticed that the runs are much more consistant. Is this possibly due to the Pro RR vs the GT2?
It appears to me that the slower times to 50 are somewhat due to the Pro RR rather than the mods.Especially the 0-10 time.
I think it's hard to make a case that the mods were worth any horsepower.The differences are so minor that the could be due to weather conditions or minute differences at the start.
Bottom line is until we figure out why your times have slowed after the 20.01 update we won't be able to make a rational judgement on wether the mods were of any power value.
Old 02-17-2006, 03:29 PM
znod's Avatar
I am sure that there were no systematic and significant weather differences (i.e., the weather conditions did not change in any significant way over the trial period) or driver differences (e.g., I started the same way each time). And, one would hope that random differences would tend to cancel out in the tests. IMO, the only way I could have improved the tests would have been to have many more trials, but I was not willing to wait that long to get the mods off. I am highly satisfied with the conclusion that the mods were not helping my car and are likely to have been hurting its performance. I may advance the second part of this conclusion more strongly if my car continues to improve.
I don't really see how I can ever know if the mods ever helped my car since I did not benchmark runs prior to their installation. In other words, even if I find out what is hurting performance, doing so won't tell me anything about my car with and without mods prior to 20.01.00. While very fast, my car might have been even faster without the mods under 19.01.00. As mentioned, SOP told me they were helping, but you know how tenuous SOP measures can be. Another problem is that my modded car became fast only after continued testing which suggests that its quickness was at least a partial function of learning and, thus, not all attributable to modding.
Quick Reply: Minimal Mods: B&B Exhaust/Dinan Throttle Body
