Been on YouTube looking at exhaust options. Seems like the magnaflow is the way to go. From what I'm seeing, it seems that everyone is using a different muffler. Any reasoning to their choices? From what I can see, the 14816 and the 14862 are the same sound, or am I wrong?
2nd question: I will be upgrading to an M-Tech rear at some point and will want to do a quad setup. Everyone is using the same mufflers on each side right? So all I will have to do is change the piping a bit to add the 2nd muffler, and keep the first? |
I chose the 14816 because of the tips.
For quads. You'll need a dual inlet and outlet Magnaflow muffler. There isn't enough room on the passenger side for same muffler you get now. The passenger side is taken up by the battery. |
With the 14816 did you get any interior drone? I hear people complaining about it with RPI and other exhausts. I have seen your video on Youtube and think this is the muffler for me but I am hoping that the drone isn't bad...
Thanks! |
I have the 14816 and its really good. Only drone (if any) is under acceleration at about 1500RPM.
But its not bad at all. |
