m5 rims on 530xi
Old 11-22-2009, 07:48 AM
dmateo's Avatar
My Ride: 06 530Xi
ok guys so i finally decided on the rims that I want..... from what I hear due to the staggering they really cant be done unless theres some light modification (530xi). Can anyone provide any insight on this topic?
Thanks
Old 11-22-2009, 08:04 AM
luigi524td's Avatar
Thanks
I think it's a off-set conflict that you need to be aware of!
Old 11-22-2009, 08:07 AM
dmateo's Avatar
My Ride: 06 530Xi
Yes from what I've been told I'd need wheel spacers.... not too knowledgable on this topic.
Old 11-22-2009, 08:13 AM
luigi524td's Avatar
Thumbs down
I'm sure C's Bimmer will chime in soon - or pm him for expert advice!
Old 11-22-2009, 08:29 AM
dmateo's Avatar
My Ride: 06 530Xi
i dont think it can be done ..... what if I get all 4 of them 19 x 8.5??
Old 11-22-2009, 08:31 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
The offset (ET number) is pretty low on M5 wheels, and X models require quite high offsets. Putting a spacer between a wheel and a wheel hub will reduce the offset even more!
I think there is no way you could fit original M5 rims on your Xi. If you really like the styling of them, you should look foor replicas with high offsets. But replicas are always just replicas and with a high offset they will not look the same.
- Antti -
Old 11-22-2009, 08:36 AM
DrLev99's Avatar
They won't fit....do some searching on xi's and wheels. There are no OEM 19's that will fit, except for some X5 or X3 rims.
Old 11-22-2009, 11:06 AM
dmateo's Avatar
My Ride: 06 530Xi
So will X5 rims fit?
Old 11-22-2009, 01:37 PM
C's Bimmer's Avatar
They won't fit. As for X5, are you referring to the E53 or E70? The center bore size vary on both, so now you have this and the offsets to worry about.
Old 11-22-2009, 02:56 PM
bobbyt's Avatar
I have an xi they wont fit just buy 19x8.5(reps) throw on rear spacers call it a day
Quick Reply: m5 rims on 530xi
