M5 offset wheels on 530i > Safer aspect ratio than stock?
Old 03-05-2011, 07:47 PM
ZGERMAN's Avatar
My Ride: 2007 M5
Hi, guys
From researching countless posts on this board (!!!) I'm pretty sure that the "best" 19' tire size for my 2007 530i should be F: 245/35 and R: 275/30, and the ET varies by wheel.... correct?
However, I just bought some 19' SF-71 on Craigslist and they came off an M5. Their offset is ET35 (front) and ET20 (rear)? at least, that?s what the post said. -- Is that possible?? I?m still waiting for confirmation (or correction), but would like to do some tire research in the meantime.
To sum it up:
A:>> Can I run wheels with the stated offset if I use the stock front bumper & the OEM M5 rear on my 530i (OEM Sport Suspension)?
B:>> Some time back, I read that some folks on this board are actually running 19' F:255/R:285 tires on their E60s without rubbing (?but I cannot find the post anymore...). Moreover, I just found a post by Anzafin that stated 285s on rear is fine.
So, what aspect ratio (tire height vs. width) would you recommend if I wanted to run F:255/R:285 tires and "play it safe" with regard to the lousy roads (potholes & bumpy train crossings) around here, as I don?t want to bend or crack my rims. Of course, rubbing should be out of the question, too. Or, is 255/30 and 285/35 the only option?
I understand that choosing a larger ration gives me more sidewall protection and stability, which is probably what I?m looking for.
Could I do 255/40/19 and 285/35/19, or would that be a bad idea? e.g. look flat-out st*pid? (TireRack has those sizes available, at least?)
Your expert advice is much appreciated? Thx!
Old 03-05-2011, 08:39 PM
525iEnjoy's Avatar
Sounds like you got "M3" set up you'll need hub centric spacers for the front( M5 are 12F 28R). You'll have to mod your front fenders to fit a 255 on the front. Best tire size is correct a 285/35 might not fit if your offset is 20 they'll stick out to much and could rub. A safe setup would be 245/35 F and 275/35. The speedo might be off but you'll have rim protection
Old 03-06-2011, 09:32 AM
TheRacerBoss's Avatar
My Ride: Bmw
You cannot run 255/40/19 on the front with a non-m5 fender.
The Max you can go is 245/40/19 - I have this setup and have no rubbing at all on my front.
On the rear I believe you should be fine running 285/35/19 if you roll your fenders but with those offsets you have cant say for sure.
If I were you I would run
245/40/19 on the front
275/35/19 on the rear.
PS - You might\might not have to ROLL YOUR FENDERS on the rear.
Old 03-06-2011, 12:31 PM
ZGERMAN's Avatar
My Ride: 2007 M5
Thanks, RacerBoss... that makes sense!
Have a hard time finding the Conti Extreme DW (245/35) in stock anywhere anyway, so I might just get the 245/40 instead.
Good call, bro... much appreciated!
Almost forgot about wanting to "play it (a bit more) safe"...
Old 03-06-2011, 02:02 PM
ZGERMAN's Avatar
My Ride: 2007 M5
One more quick question, TheRacerBoss:
Do you have spacers on your fronts?
The wheels tires I'm getting are ET35 (front), and that's why I just bought 15mm spacers.... should work OK with the 245/40-19 front tires, right? The rear wheels are ET20, so I won't need to change anything here... if my math is correct.
What do you say?
Would be nice to know that I did something *right* for a change... LOL
Thx,
Armin
Old 03-07-2011, 08:47 AM
My Ride: Bmw
I dont have spacers on my front, its just the M5 wheels and let me tell you, its pretty far out with those 245/40/19.
Tire protection man, I just drive on pot holes and know for sure that I am safe. It might sound silly how I say that but I was running 245/35/19 on my front before and may I spell out my experience
1. HEAR the road
2. Fell every damn pebble on the streets man
Now -- I with the 245/40/19 -----I just GLIDE
As long as you have the M5 oem offset size you should be fine my friend. Just check on the offset numbers for both again. I know when I was installing that 40 profile tire, the distance between my shock absorber and my tire was only a pinky. So the tire was like a perfect match to the maximum limits.
The reason I tell you that my front M5 wheel is pretty far out is because when you have a 40 profile tire the side wall is a little rounded -- Thus needing a little more space, if you know what I mean.
Old 03-07-2011, 10:29 AM
525iEnjoy's Avatar
1. HEAR the road
The offset will be 20 on his setup, not 14mm..It will be close.
Old 03-09-2011, 03:05 PM
ZGERMAN's Avatar
My Ride: 2007 M5
Hey, RacerBoss...
I'm *theoretically* aware that there is such as thing as "aspect ratio" (=ratio of sidewall height to section width)... which is - in your suggestion - 40 for the fronts, and 35 for the rears.
BUT...I've never been any good in math, and that may just be the reason why I can't figure out why the ratio of the fronts is higher than the rears....??!
Shouldn't that be equal, or vice versa... and if not, what does this mean?
I just got my rears delivered (fronts arriving tomorrow), and aside from the fact that they look awesome (read "super-wide"), they look rather "low profile".
So, why is it that I'm running a larger profile in the front... because of weight (=engine)?
I actually am a bit concerned about the looks... and got a little bit nervous in the process ... (as you probably can tell ...LOL)
Please be so kind as to "illuminate me"...
Thanks,
Armin
P.S.: I got Conti DW in F: 245/40-19 and R: 275/35-19... as suggested
Old 03-10-2011, 02:21 PM
My Ride: Bmw
I will PM you and explain how it is done
Old 03-10-2011, 02:42 PM
My Ride: Bmw
Why are profile ratios in the front higher when compared to the Rear ?
Okay,
1. You agree that both your wheels are 19inches diameter (Correct)
2. So now considering the radius for all 4 wheels will be 9.5 inches (Correct)
3. Our main goal with the calculation on the tires here is to have all 4 tires add the same height to the car all over (Correct)
4. Okay, now look at your rear tire
It is 275/ 35/19
Forget the 19 since that is common on all 4 wheels
consider 275/35 = Lets actually do the math on these
What is 275 * 35%
275* 35/100 (275 multiplied with 35) then divide by 100
= 96.25 (Correct)
So your sidewall height is 96.25 mm on the Rear Tyre (Remember this)
Same way for the front
245*40/100
= 98 mm
So now we are Xtremely close, there is virtually no difference between 96.25 and 98mm (correct)
You will say -- Racer they are different and they are not the same.
Okay let me explain
Convert mm to inches (Google a mm to inches calculator)
Converting 96.25 mm to inches = 3.78 inches (Lets say 3.8 inches)
Converting 98mm to inches = 3.85 inches
Now let me ask you -- Can your eye tell me the difference between 3.8 and 3.85 inches on a tire mounted on a car
IT CANNOT (period)
Thats why they are virtually the same.
Now lets suppose you had gotten a 35 profile tire in the front
you would have to buy 245/35/19 -- Do the math again
245 * 35 / 100
85.75 mm
3.3 inches
Comparing 245/35/19 and 275/35/19 on your car
front in inches will be 3.30
Rear in inches will be 3.85
you will have a front tire that is half inch shorter than the rear tire (lol) A sharp eye can catch this very easily
You dont want that buddy!
Quick Reply: M5 offset wheels on 530i > Safer aspect ratio than stock?
