Lug question for BBS RS-GT wheels
I need some lugs for my BBS RS-GT wheels for my 07 550i with spt pkg.
I would like some black ones, where can I buy them? Also I read somewhere
there is a conversion kit to make my lugs, bolt on instead? Anyone have any idea?
Also I was told I could use the TPMS from my stock wheels but need longer valve stems?
If so where can I get them besides the obvious tirerack?
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
Wheel bolts (black) are standard fitment so I am puzzled by your question.Have you fitted spacers which have studs?
If you plan on getting lugs might as well get spacers with your new wheels then you get new lugs and in blk like the way you want it. The spacer will give your car a better stance and look more aggressive.
My Ride: 2005 BMW 545i
No idea where to get black bolts or the conversion, my car came with a set of black bolts with locks. You could see if you can buy it from the OEM parts vendors (like Gary at Newport) or at www.getbmwparts.com.
As far as spacers go, IIRC the offsets on the BBS RS-GT in 20" E60 fitment are 8.5" front wheels with +15mm offset and 10" rear with +22 offset so they're stanced pretty well from the get go. I'd recommend going no lower than +19 on a 10" rear with 245/30/20 sized tires if you have your fenders rolled. The fronts should sit perfectly though.
You have some sick wheels, I'm jealous. Pics are a must!
You can get black bolts from your BMW dealer ,part number 36136781150 and also from :-
http://www.bavauto.com/shop.asp
The_Sauce
06-26-2015 07:40 PM
