Lowered car = Wheel Alignment
Old 11-28-2008, 03:23 PM
Speed_Force_E60's Avatar
So I got my ride lowered on H&Rs about a month ago, but since then the #1 question I've had since lowering it is "Did you get a wheel alignment too?"
Is this absolutely necessary? The car rides straight and doesnt veer to the left or right... but i've been told that if the wheel alignment is NOT preformed that I may face adnormal tire wear? Can someone confirm this? Otherwise ill have to get this done asap.
Old 11-28-2008, 03:27 PM
ENstig8or's Avatar
My Ride: 650 Grand Coupe
Model Year: 2016
Everything I've read in these forums says that you need to get an alignment.
Old 11-28-2008, 04:02 PM
DrLev99's Avatar
Yes, you need an alignment. Dropping the car throws off the camber most of all....the tilt to the inside (top leans in more than bottom) aka negative camber, tends to be increased beyond spec (more negative). Your inner part of the tires, esp. the rear ones, will wear much faster than normal.
Your car may track straight now, but you wouldn't be able to feel the camber being off. Certain other specs will also be off, like caster, which they won't be able to correct....since it's set at the factory. You need to be most concerned with camber and toe components after a drop.
If your mechanic cannot get the front end back into spec, he should remove some camber pins at the top of the front struts. Once he does that, he should be able to get all 4 wheels back into spec with respect to the the camber and toe.
Old 11-28-2008, 04:28 PM
BALASUBAS's Avatar
+1
Old 11-28-2008, 05:26 PM
radzM's Avatar
Thanks for the info Doc!
C's Bimmer's Avatar
You sure do. I had both of my E60's lowered and both times I had an alignment done. It's a must!
Old 11-28-2008, 05:27 PM
wheel alignment is recommended every time the ride height changes
I can get you an alignment but it will be down in Irvine area.
Old 11-28-2008, 09:17 PM
John Photography's Avatar
Alignment is a must! But I got an alignment and 4 corner balance and it made such a huge difference in ride quality!
Old 11-28-2008, 09:22 PM
radzM's Avatar
where's the best place and best price to do it John?
Old 11-28-2008, 09:57 PM
+1 Where at John? I dont want to drive all the way down to Irvine so help us out here bud
Quick Reply: Lowered car = Wheel Alignment
