Looking to change my springs again
My Ride: 530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats, Cold weather package and M5 OEM 166 wheels, Sprintbooster. Ceramic Tint all around, Bilstein Sports shocks with Eibach springs, Brake performance Rotors and Axxis ceramic pads.
I recently installed an Eibach prokit springs and Bilstein Sports struts and shocks. Front end dropped about 1.4 inch but the rear end only dropped 0.5 inch. I just want to close the gap between the fender and wheel but not slammed it. Currenlty contemplating on changing the eibach front springs to an OEM sports package springs. Here is now my delemna, I called Gari from Newport and he said he need to have the last 7 digit of the VIN. Since I don't have a sports package I can't use my VIN. He said I need to get a VIN # of a car close to the equipments I have with a Sport package. So he can order the right springs. I need help for someone with atleast close to the equipment I have to volunteer the last 7 digit of their VIN. Need help badly
Originally Posted by EV4530' post='874622' date='May 10 2009, 10:36 PM
pm sent
AL
My Ride: 04 525i, 04 Dinan M3
Got a question, for sports suspension, is it as easy as changing springs? Or do you have to change shocks too? I'm on stock non sport now.
the oem sport springs will not drop the car the way you are looking for
even with bigger wheels there will still be a rear fender gap, the fronts will be goo though
you have to get coils if you want to eliminate fender gap
Originally Posted by al_ongvano' post='875039' date='May 11 2009, 09:20 AM
Exactly what I want to do. Raise the front end from its current state(eibach prokit springs) to an OEM sport suspension springs. I will keep the rear eibach springs> Hopefully I will have the effect I need.
but you will two different spring rates in the front and rear if you do that then
buy some ground control springs and you can adjust the ride height and have the same spring rates all around
My car is now in for a Eibach Pro Kit spring modification.
My car had, and will have, the standard springs.
They say that the car will be about 30 mm lower!?
My Ride: Bmw 530d 2004
