LOGIC 7 driving me insane
In my past thread i had an issue with my jl 1000/1 amp and 13w7, the amp was faulty and is replaced. NOW another issue, i noticed that my bottom logic 7 sub cut in and out, mainly the driver side. Its the signal coming from the LOGic 7 amp. When my driver side sub cut out i went into the trunk and tried to wiggle wires around, but all my connections are tight. I removed and inserted the DSP plug( the one with the red laser that controls the signal and crossovers) and the right side kicked back in. I have no idea what the issue is and how to solve this. It happens intermediately. Also i should mention that i have TAPPed in to the left and right sub wires for my JL 1000/1 amp. Do you think the resistance is increased by having the bottom seat subs and W7 working through the sub inputs of the LOGic 7 amp, thus causing the signal to cut off.
Also I did remove the bottom seat and had the w7 running alone and same issue occurred.
macantley
03-31-2015 03:44 PM
E60-530d-London
02-24-2004 04:11 AM
