LCI Retrofit Facelift Lights
The LCI retrofit is a retrofit cable set for the facelift lights. This is the BMW OEM solution to get the facelift headlights and taillights working on pre-LCI cars. A new light module (LM) needs to be installed on cars before 09/06.
Part numbers:
E60: 61 12 0 432 110
E61: 61 12 0 432 397
The cable kit consists of many parts (adapters, sockets, etc.). A person would have to buy the facelift headlights, taillights and light module separately.
The TIS document states an approximately 5.5 hours. But I would think it is much longer for older cars or when troubleshooting arise. It sounds like a 2 days labor extensive dealer job! For the taillights, couple of the wires from the cables need to be routed all the way to the front of the car--connecting the pins directly to the dismantled plug on the LM. The headlights require bumper removal. The pre-LCI existing plugs (the 8-pin plug and 4-pin plug) have to be completely disassembled. A provided 12-pin socket will then be individually wired and this plugs into the facelift headlight. And finally the car is program/encoded.
![LCI Retrofit Facelift Lights-lci_retrofit_cable1.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/40055d1482365509t-lci-retrofit-facelift-lights-lci_retrofit_cable1.jpg)
![LCI Retrofit Facelift Lights-lci_retrofit_cable2.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/40056d1482365509t-lci-retrofit-facelift-lights-lci_retrofit_cable2.jpg)
![LCI Retrofit Facelift Lights-light_module.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/40057d1482365509t-lci-retrofit-facelift-lights-light_module.jpg)
![LCI Retrofit Facelift Lights-headlight.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/40058d1482365509t-lci-retrofit-facelift-lights-headlight.jpg)
Part numbers:
![LCI Retrofit Facelift Lights-taillight.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/40059d1482365509t-lci-retrofit-facelift-lights-taillight.jpg)
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
Do you know how much for all the hardware and estimated labor costs for the install?
The approx. price breakdown...
a. AHL-xenon headlights: 1,850
b. Taillights: 430
c. Light module: 350
d. Retrofit cable set: 50
e. "Labor": 1,000
Give or take, somewhere between $3.5k to $4k out the door.
b. Taillights: 430
e. "Labor": 1,000
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
Originally Posted by coolguy' post='490739' date='Nov 6 2007, 09:55 AM
So Rear Tailight = $430 + $50 cable?
I think you will also need the light module
Originally Posted by coolguy' post='490753' date='Nov 6 2007, 10:20 AM
I thought the light module is only for LCI front headlights right? LCI Rear only needs a retrofit cable isnt it.
4-5k for lights... I think we all would agree that you can do a lot more with 4-5k, than just lights. =)
Get some 20 inch rims! or.. bodykit, and rims and springs. heh.
So much. or just keep the car the same and get a motorcycle, Used of course. If you want speed that is.
If is cool that BMW offer's the retrofit cables and such, but its just so expensive.
MK
MK
