LCI LED ANGEL EYE - LAMP FAIL WARNING
HI
ANYONE HELP - I HAVE CHAGED OUT THE YELLOW OEM LAMPS WITH XTEC LED TYPE AND THEY WORK FINE BUT THE ONBAORD LAMP FAILURE SIGNAL IS COMING UP EVERYTIME THE IGNITION IS STARTED. THE CAR HAS ADAPTIVE HEADLAMPS WITH ZENONS AND ALL SEEMS FINE WITH THESE.
HAS ANYBODY ELSE HAD THE SAME PROBLEM
IAN M
IAN M
Wow ... ease up on the caps ...
The new LED bulb you replaced may not have the proper resistance so you may need additional resistor.
socale39
09-05-2023 08:30 AM
Tsoup
15
12-20-2021 11:14 AM
