LCI Headlight Retro Fit.
Old 07-28-2009, 09:57 AM
Eugene134's Avatar
My Ride: F10 535I
Model Year: 2016
I know this has been discussed before.. What is needed to retro fit LCI headlights on a non-LCi and what is the cost.
thanks
Old 07-28-2009, 10:16 AM
nigxdoof's Avatar
its costs... $$$$$$$$
Old 07-28-2009, 10:28 AM
bruce_miranda's Avatar
What are you starting from on the non-LCI. Halogens? BiXenons or AHL?
Old 07-28-2009, 10:31 AM
Banned
John@Motorcepts's Avatar
My Ride: A Car
he has bixenons. I am wondering if we can splice the connectors to make it work instead of programming.
Old 07-28-2009, 10:35 AM
If you have BiXenons and you are just putting on LCI BiXenons, then I'm pretty sure you can just convert without reprogramming. Will need some new plugs for the headlights - but that is the easiest bit.
nigxdoof's Avatar
We wish it was that simple. Contact Blastwi. He did it. =)
Old 07-28-2009, 10:36 AM
BlaSTiWi's Avatar
What's the end target? Full OEM function?
I did just the headlight retrofit w/o programming no problem, but you don't get all the function such as soft on/off.
Cable splicing can be done in fact the retrofit cable cost only +/- $40 (which includes front plugs & tail adapter) from the dealer.
You'll have to deal w/ some iDrive warnings since the AE & hi-beam are different.
Banned
My Ride: A Car
Oh, what about if u have adaptive headlights? Are the plugs the same? Anyone have a picture of the plugs for the LCI and pre-LCI for comparsion? I know also that the LCI no longer has the inner high beams.
Old 07-28-2009, 10:38 AM
Banned
My Ride: A Car
Originally Posted by BlaSTiWi' post='956942' date='Jul 28 2009, 02:36 PM
What's the target? Full OEM function?
I did just the headlight retrofit w/o programming no problem, but you don't get soft on/off.
Cable splicing can be done in fact the retrofit cable cost only +/- $40 from the dealer.
i wonder if there r resistors we can also splice in to get rid of the error messages. And if I retrofit it, I can use HID H8 angel eyes without a problem.
Old 07-28-2009, 10:43 AM
BlaSTiWi's Avatar
Pre-LCI plug:
LCI plug:
The pins inside the plug are all diff ... pre LCI uses round pins.
Quick Reply: LCI Headlight Retro Fit.
