KW V2 coilover owners - did you remove helper springs?
My Ride: 2009 E60 530i
Hey guys,
Those of you with KW v2 coilovers, or any KW coilover for that matters, did you guys remove the helper springs at the front axle? I heard doing so will give more clearance to the front tires? I have to run at least 10mm spacers on the front (18x8 ET20), and I'm looking to buy a new set of rims, which has the same offset as my stock wheels, but wider (19x9 ET20), which will have even less clearance to the strut housing. I heard the helper spring does nothing but keep the spring rate constant, and removing them will have no influence on handling or comfort. Has any of you done this?
Thanks
Thanks
socale39
09-05-2023 08:30 AM
