Koni Yellows?
My Ride: 2008 550
DPE S7
CF Front Splitters
Hey Amigos
I'm putting my Eibach springs back on after a long and expensive lesson, and was talking to a guy that can do this for me, but he mentioned I should get new shocks because the stock shocks will blow out after 5-10k miles. Is this the case? I didn't plan on that big of an investment, but also don't want to kick myself in a few months when my stock shocks blow out.
So he mentioned Koni Yellows as good quality but also being able to save a few benjamins.
Advice is appreciated!
it varies on how fast your stock shocks will wear out but for sure they will wear out quicker than usual. also most do prefer to do springs and shocks together not only to not worry about shocks later on, but to get everything done altogether to save on labor.
That is true. It is strongly recommended you also replace stock oem shock when replacing springs, even if you have oem sport shocks. These oem parts are designed to compliment each other, but not aftermarket parts/upgrades. Plus, shocks are considered wear items and since replacing springs require removal of the shocks you may as well "kill two birds with one stone."
Can't speak for the Koni's (they've got good reviews btw), but I'll vouch for the Bilstein Sports since that is what I currently have matched to my Eibach ProKit. I absolutely love this setup. As long as you replace your oem shocks with sports shocks, you should be fine. I'm sure others will chime in recommending coilovers, which is another alternative. good luck
My Ride: 2008 550
DPE S7
CF Front Splitters
That's what he said too....to save on labor. Are the Koni Yellows any good? I've done some research and they seem to get good reviews, but mostly on Asian cars.
I have the Eibach's and Koni Yellow sport shocks. I think its a great kit! If you get it DO place the bump stops back on the shocks, and cut them down a bit to shorten them.
I have mine turned slightly harder but even then the ride doesn't suffer. Its about as good as it gets without going to coilovers.
My Ride: 2008 550
DPE S7
CF Front Splitters
What kind of ride can I expect with the new shocks and springs? My stock set up is super smooth, but I get alot of roll when cornering too fast.
My Ride: 2008 550
DPE S7
CF Front Splitters
Thanks Dutch, that's the exact set up I'm looking at. Joining this forum has bee educational to say the least
![Cool](https://5series.net/forums/images/smilies/cool.gif)
btw, the bilstein sports won't require re-using your oem bump stops since they are "built-in" the shocks
Koni Yellow Sports are Firm but not rigid and bouncy. I drive on full firm and sometimes its a lil harsh here and there. Full soft is factory smooth with great steering, Full Firm is sporty and steering feel is precise, either way you go though the steering wheel never veers. I have had the Koni's for 28,000 daily driven miles.
![](https://5series.net/forums/public/style_emoticons/default/thumbsup.gif)
it depends on your driving habits as well. I was told the same thing when I had them on my S2K, I had them for 13K miles with no signs of blowing. Can't really go wrong with Eibachs.
