Jlevi SW | Introducing our Version 2 32LED High Output LED Bulbs
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
Hey guys
After experiencing great success with our Version 1 24LED turn signal kits, JleviSW is proud to present our 32LED high output LED Bulbs.
Perfect for your front or rear turn signals, backup bulbs, and more!
A great upgrade to your existing LED turn signal kit from Jlevi SW! Simply purchase bulbs only to upgrade to the latest look!
Standard Setup Includes
-(2) LED Bulbs of your select fitment & color (Each 32 LED Matrix Design, except 7440 which is 30LED)
-LIFETIME WARRANTY
-Unlimited access to installation guides and technical support
Recommended Upgrades for Turn Signal Installations:
-Load Equalizers to eliminate "Bulb Out" warning, including (4) wire taps to install Load Equalizers
Benefits of LED Turn Signals: (New Features in Red)
-Instant on, instant off blinking. No more slow "fade" blinking like halogen bulbs
-Improved output LEDs, and more of them, to help fill the entire housing with bright, colorful light
-Improved 6000K color - Unmatched by any "hyperwhite" halogen bulb (For Xenon Kits)
-Virtually no heat from actual bulb
-Improved, Richer Amber color for Amber bulbs
-No egg yolk - bulbs are perfectly clear when off
-Reduced price as compared to many "Chrome" bulbs (Many of which cost as much at $75!!!)
-Never burn out!
Installation of LED Turn Signal Kit:
-Bulbs simply plug in. No modification required to the housing
-Load Equalizers tap in with easy junction taps (SEE DIAGRAM)
-Upon purchase, you will be emailed the link and password to our Complete Instruction Guide with color pictures and multiple installation suggestions. We are the ONLY retailers who provide this instruction guide.
Please Note:
-Load Equalizers, if purchased will heat up to roughly 300 degrees Farenheit. Consequently, the equalizers have 15" wires on each end, to allow you to run them into a FREE AND CLEAR area in the engine bay. Our instruction guide offers 3 possible solutions for mounting them to a METAL, NON-PAINTED surface, away from plastic or flammable components.
Superior 32 LED "Matrix" Design:
![](http://www.jlevisw.com/images/LEDDiagram132.jpg)
![](http://www.jlevisw.com/LEDDiagram2.jpg)
Click the photos below for more information, or to order. These bulbs are currently IN STOCK and shipping in the following fitments:
194/168
1156/7506
7507
3157
7440
We are continuing to sell our renowned Version 1 bulbs at a great discount!
Thank you!
Jonathan Levi
Founder
-LIFETIME WARRANTY
-Never burn out!
Please Note:
194/168
1156/7506
7507
3157
7440
Thank you!
Jonathan Levi
Founder
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
Can you post a pic of the diagram?
Model Year: 2005
Engine: 545i
You can't wire tap the front indicators on a E60. The circuit is intergrated in the housing.
It's possible to add resistors using a different technique but not wire tap directly to the indicators.
The bulb also needs to be the offset type.
Sounds like you've done that before andy....
![Innocent](https://5series.net/forums/images/smilies/imported/innocent.gif)
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
Thanks for the interest guys. Right now we are doing these for our introductory pricing, $40 for the amber and $42.50 for the xenon white (includes resistors). We'll try to get some E60 pics up for you guys, anyone local want to stop by for a photoshoot (Santa Clara, CA)?
