iPod interface vs iPod USB/AUX
My Ride: /// 2006 | 530I | Silver Gray Metallic | Sport / Prem / Navi / IPod | LCI EURO SPEC Tail's | LED Licence plate bulbs | LED side turn indicators | Roof Spoiler MORE TO COME!!!!
I have been looking on here for a while and cant figure out how to install this.
I have a 2006 530 with the iPod interface installed. I have a iPhone 5s which has the new lightning port. I am not able to use it with the 30-pin iPhone wire. So i found a temporary solution but would like a permanent one.
1. Is there a way to get a new cable for the iPod interface using a lightning port wire?
OR
2. Can I just remove the iPod interface and install a USB/AUX port in the center console like the 2008+ (LCI) e60's have...
Thanks!
OR
Thanks!
OR
Thanks!![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
OR
Thanks!
you need the mulf2 high and some cables usb hub and some coding jobs and clear.\
if you have option sa644 mulf you can replase it with mulf2 high and add 6fl with ncs in lma and cas it will be work i think.
regards,
530dA
Thats great! ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Do you know of the part numbers needed by any chance and a write up of the installation process?
Thanks
Thanks
these retrofot is for when you do the mulf in the glove box, buth wenn it go to trunk make easy the vonnectors longer
parts you need here you go
mulf2 high basis svs
retrofit harnas: 84640441949
usb/aux bus: 61319129651
usb mulf cable: 61119202728
61138380696
61131393724
cable 4x 0.35mm2 1meter
8 pin house mulf2 54 connector
pin1 pin23
pin2 pin22
pin3 pin5
pin4 pin4
regards,
530dA
bestofthebest
03-28-2016 02:47 PM
