Ignition PROBLEMS... Aftermarket Audio or maybe old Battery;s fault?
Hi guys,
I recently installed a new audio set up I bought from member GEORGIEB with the help of NELSON29.
I have
2 Tru Technology amps 400W each (I think)
1 12 JL Audio 12w7
1 Monoamp 1500W RMS
+Jehnert door boards
I suspect I should have no more than 1500RMS in total audio, right?
Everything was working fine, now, all of the sudden, a week ago, I came back from running some errands, parked the car, everything was OFF.... Came back next morning, got ignition, all lights went on, BUT, the car would not start, matter fact, MY CAR WOULD NOT EVEN MAKE THE GRUNT you get when the battery is low... nothing.
Mechanic came over, charged the battery in full, nothing, he plugged a machine to infuse a bit more voltage than usual, nothing.
He took it in, after 3 days of tests, he called and said;
1- They re-programmed the start up "module", and the car started, turned it off again with all audio parts plugged in, came back 15 later, car wouldn't turn on, same as before. they re-programmed again, car worked, but then after being turned off again with all audio.... same problem.
second test
2- THEY UNPLUGGED THE AMPS, re-programmed the car and ran the same tests, car came on, but after leaving it off WITHOUT THE AMPS, the problem was gone, car would start with no problems.
My battery is an OEM battery, probably 2-3 YEARS old, they will replace the battery tomorrow for one more powerful, but, do you guys think it's the audio or most likely a crappy battery giving me the problem?
I have
1 12 JL Audio 12w7
1 Monoamp 1500W RMS
second test
I'm posting in case someone has had a similar problem.
My Ride: 06' BMW 530xi
Why don't you just get a second battery for the audio alone? There batteries selling specially for audio I think kinetik is the top battery being used now
Here in Costa Rica they are quoting me a Kinetic 1400 in like $420
My Ride: 08 528i TiAg Premium/Cold Weather Pkg, 20% Tint, Technic Harness, JL Audio 12W7, JL HD 750/1 and LOTS of lighting mods!!!!!
Hi guys,
I have
1 12 JL Audio 12w7
1 Monoamp 1500W RMS
second test
I have
1 12 JL Audio 12w7
1 Monoamp 1500W RMS
second test
Kdarcia007 I also have a Rockford Fosgate 2 fared capacitor for sale if your interested
Awest91
09-17-2022 11:05 PM
