idrive knob removal
Old 07-13-2011, 07:29 PM
viper1213's Avatar
I am currently trying to start retrofitting my car to ccc and I am trying to remove the I drive knob and I took out the initial knob by pulling straight up. There is a white dial right under the knob and I'm not sure how to remove it. I checked georgieb's thread and still confused I don't see how he took it out. Thanks everyone.
Old 07-13-2011, 08:56 PM
flyingpuck's Avatar
Take a picture and post it!
Old 07-13-2011, 09:42 PM
umichchris's Avatar
My Ride: ///M5 BEAST
here's a pic. i started my install as well...the first step for me will be cutting the base plate for a CiC iDrive controller retrofit (gotta get my $$ worth with this new dremel tool!)
looking closely at it all....i think the entire center console needs to be lifted out. so i went to real oem and found some diagrams of the center console to find the screws/locking pins.
unless, someone has an easier route.
Old 07-13-2011, 10:04 PM
viper1213's Avatar
sorry was busy trying to figure it out here's a pic
Originally Posted by umichchris
here's a pic. i started my install as well...the first step for me will be cutting the base plate for a CiC iDrive controller retrofit (gotta get my $$ worth with this new dremel tool!)looking closely at it all....i think the entire center console needs to be lifted out. so i went to real oem and found some diagrams of the center console to find the screws/locking pins. unless, someone has an easier route.
yea it seems like we got the same problem i was thinking about taking the whole console out as well but i've seen others who i believe accomplished it without doing so
Old 07-13-2011, 11:24 PM
Anzafin's Avatar
My Ride: Bmw 530d 2004
You are right, the center console must be removed/lifted before you can remove the item.
1) http://tis.spaghetticoder.org/s/view.pl?1/09/09/29
2) http://tis.spaghetticoder.org/s/view.pl?1/09/09/32
3) http://tis.spaghetticoder.org/s/view.pl?1/08/86/54
- Antti -
Old 07-13-2011, 11:57 PM
viper1213's Avatar
Thanks alot Antti i really appreciate it i was scratching my head all evening over this. Hopefully the rest of the install goes smoothly. I owe you
Old 07-14-2011, 08:48 PM
umichchris's Avatar
i got mine out this afternoon....
found this damn DIY after three hours of trial and error and figuring it out myself. look at this in case you havent figured it out yet...
https://5series.net/forums/topic/994...5#entry1207895
Old 07-15-2011, 01:26 AM
viper1213's Avatar
Yea thanks to Antti i got it out im actually in the process of cutting the trim did you switch the wires for the cic controller yet does the plugs come out easily?
Old 07-15-2011, 05:07 AM
umichchris's Avatar
here is a link to how to wire it:
https://5series.net/forums/topic/994.../page__st__240
i use a little tiny pin to get in there and release each little plug...i learned that when i was re-wiring my mirrors this past wknd. once u learn that pushing on the head of the wire clip releases it and allows you to slide it out of the plastic connector/housing....it makes it really easy to take out each plug, switch them around and effectively re-wire whatever you need to work on.
on a sidenote, your wiring harness/plug should arrive in the mail today via USPS.
im about to measure 3x and cut once on my center console right now....its sitting in the middle of my living room as i type this. had to give up on coding tho, i kept getting a VIN is Faulty error in NCS Expert
Old 07-15-2011, 06:22 PM
umichchris's Avatar
today was a BUSY day...but i got it all installed....headed to the dealer in the morning for coding and we should be in business!
peep the before and after photos lol
Attached Thumbnails idrive knob removal-center-console.jpg   idrive knob removal-photo-22-.jpg
Quick Reply: idrive knob removal
