i want spacers but im scared!!!!
My Ride: 530i
Does anyone have spacers w/ Iforged wheels?? right now in the rear i have 20x10" Iforged wheels (non bbk) and am pretty much slammed on on coilovers (can only fit one finger between wheelwell and tire), but i feel that the stance is not wide enough in the rear and want to get 10mm spacers...do u guys think i will have problems w/ rubbing?? I currently do not rub at all!!!
My Ride: No mods
in my opinion, u can try to put spacers in and see what happend. at the meet yesterday at wheel power, iceman316's car had no space in the back, his tire was tuck inside his fender. i guess you can ask around or ask the heavy modders here like EuroCarFan
My Ride: E60 M5, F85 X5M
:'( I actually have no experiences with spacers so I'm clueless. You should ask Vegastrashed.
But now that you've brought it up, I've never noticed how my rear tires look and I have coilovers as well....
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Can you post a picture of the rear? What are the dimensions of your rear tires?
My Ride: 2005 530i JETBLACK/BLACK DAKOTA, COLD WEATHER PKG, PREMIUM PKG, ADAPTIVE XENON HEADLIGHTS, AUTO TRANSMISSION WITH 6 SPEED STEPTRONIC, BLUETOOTH SETUP,SAT SETUP AND WIFE AS CO-PILOT
i have 10mm on 20x9.5 and i have a rub on harsh dips... i would assume that with 20x10...would rub.... iwas thinking of going smaller spacers ...totally forgot to ask the guys when i was at the meet if it was tooo wide....... i say go with a smaller spacer other 10mm...ericd..bye the way im no expert on this... its just i felt the same way with my car when the rims were slapped on and felt it needed to be spaced out a bit.
I've thinking about spacers for my E60 as well. Just curious... Wouldn't 5mm visual impact be sooooo small that it's not worth doing?
Originally Posted by vegastrashed' post='375189' date='Jan 8 2007, 09:53 AM
Yeah, you're right ericdbs. I think that with 20x10 that bstandardz might not be able to put on 10mm spacers. Maybe 5mm might work.
delete. Double post.
The issue of spacers depends on a few variables i.e. wheel size, wheel offset, tire size, and springs. For example, with Style 166 wheels (9.5x19), offset 28 and 275/30/19 tires, and H&R Sport springs, I can use spacers anywhere from 5mm - 12mm.
Since you have Rad R10s which are bigger and wider wheels, you might rub with 10mm spacers. Asethically, your wheel & tire setup already gives you the appearance of a wider stance. The 5mm spacers in this case might just be right for you to flush your rear wheels to the fender without rubbing.
I know that Rizbel has almost the same setup as mine. He has 166s, 275/30/19s, H&R coilvers, and 12mm spacers. After installation of the coilovers he was rubbing. He removed the 12mm spacers and is looking into getting 5mm.
