Hubcentric rings & Spacers
My Ride: Gone: 2004 545i
Does anyone know if HUBCENTRIC RINGS and SPACERS can be used together? If I'm running a wheel that requires hubcentric rings, but want a more agressive offset, can I simply add spacers or will that alter what the hubcentric rings do? Is there a higher risk of vibration going this route?
Appreciate the input.
Thanks, Mike
Thanks, Mike
My Ride: '06 550i
'84 Nissan S12 Turbo
Just make sure that the spacer is hubcentric to both the car, and the wheel. If you have some wheels that are not the right hub size for the car, then yes, you can use the hubcentric ring with a hubcentric spacer.
bestofthebest
03-28-2016 02:47 PM
umnitza
11-25-2015 11:10 AM
umnitza
09-02-2015 11:28 AM
