how to replace klima control e60
It's not that simple.
The extended climate control is a lot more than only the control panel. Some other parts and coding is needed.
On the other hand, if I remember it right, someone on the forum with advanced skills was able to fit only the control panel in his car...
Maybe you should do some searching....
- Antti -
- Antti -
My Ride: 2007 Black Sapphire 535i
slavito,
Check out our work here https://5series.net/forums/topic/994.../page__st__375 and here https://5series.net/forums/topic/994.../page__st__345. We did a complete Climate Control swap from pre-LCI to LCI however as Anzafin suggests, it was part of a much bigger project involving a complete CIC/iDrive upgrade and coding will almost certainly be required. Your success in integrating an LCI Climate Control on a pre-LCI CIC may be limited if functional at all....
Time for you to do some more research on this. You'll find a wealth of information in these forums. Good luck and welcome aboard.
BYS2
Mar 24, 2015 03:13 AM
balbs
Mar 9, 2015 01:37 PM
