How to remove Front Bumper Reflector?
Old Jan 31, 2009 | 01:20 PM
ADD's Avatar
ADD
In M-Tech LCI bumper.
The one in front of the front wheel well.
Thought it might be an easy winter project for a few hours. Paint and reinstall.
Thanks
Old Feb 1, 2009 | 01:24 AM
AlexFW's Avatar
Model Year: 2005
What are you talking about?
I don't have it
Old Feb 1, 2009 | 04:27 AM
ADD's Avatar
ADD
Hardy, har har... Wise guy.
I was thinking of just shading them a little darker, so they'd still be reflective, but not so noticeable.
From what I've read, it looks like you pry up from the bottom, and push up. Does anyone know if they are held on with adhesive or plastic "clips"?
Old Feb 1, 2009 | 04:46 AM
Howitzer's Avatar
paint them. That is what most do.
Old Feb 1, 2009 | 05:32 AM
ADD's Avatar
ADD
I would like to paint them off the car.
Do you know how they are attached?
Thanks!
Old Feb 2, 2009 | 05:18 PM
alpineweiss's Avatar
My Ride: 09 E90 M3
Thanks!
They are held to the bumper by double sided adhesive which will be wrecked when you remove it - so you are better off ordering new reflectors, painting them and do a direct swap. I did this swap on my E70 X5.
Try this thread:
http://www.e90post.com/forums/showthread.p...=e92+sidemarker
or this
http://www.x5world.com/x5-e70-forum/39331-...emove+reflector
The reflector can be accessed directly on the E92, but not on the X5. I haven't come across any E60 specific instructions, but it should give you a pretty good idea. Be VERY careful of scratching the paint when using tools to pry it off!
Old Feb 2, 2009 | 05:56 PM
dbae1978's Avatar
on the lci there is a clip that hold in the reflector. just turn the steering wheel in the opposite direction of the reflector you want to remove. Look behind the reflector and press the center clip inwards and the relflector should pop out. You might want to use a flathead screwdriver to press the clip. I hope this helped, good luck
Old Feb 2, 2009 | 06:11 PM
My Ride: 09 E90 M3
You guys have it easy!
Good luck with the mod
Old Feb 3, 2009 | 04:41 AM
ADD's Avatar
ADD
Thanks! It's been too cold to motivate me to look behind the fender.
Kasmo
May 7, 2019 03:30 AM
chadillac2000
42
Sep 13, 2017 11:15 AM
EuroStyle
May 4, 2015 05:42 PM
Spacegrey535xi
Apr 16, 2015 07:04 AM
rkilpa
Mar 4, 2015 09:10 PM
