How easy is to retrofit a sunroof on an E60?
My Ride: 2008 535i:
1992 Camaro RS:
Hacking at the roof of a car DOES alter the cars structural integrity. There is no way I'd try this as a DIY and I have yet to see an aftermarket sunroof install that didn't cause problems after the fact.
The only possibility you have with a factory sunroof would be to take that entire roof you took the pic of and cut it off at the pillars and then install it on your car. The opening for the sunroof on the body is not just a simple cutout, the metal around the opening is structured a certain way for the sunroof itself. The only other option I know of is one you would find as a non oem. A simple pop up or pop out. I wouldn't do it though...
My Ride: 2008 535i:
1992 Camaro RS:
Hold up - I didn't know you were replacing the entire roof, I thought you were going to cut into your existing one.
It could be done but its definitely not a DIY. There would be alot of welding involved and then paint-matching. There is still no guarantee you won't have any problems.
Ok, back to the original question. Yes, it's possible to remove the entire roof at the A & C pillars and swap it with yours. Obviously welding, body finishing and repainting is required. I can't imagine anyone doing this that does not have the required experience. But if they do, then yes it can be done. I've seen it before where the roof has been entirely replaced, the entire front and rear clips and the entire side clips by professionals. If I could give you mine I would, I never use it and I think the car is a little quieter without it.
My Ride: M6 F06
Model Year: 2013
My Ride: 2008 535i:
1992 Camaro RS:
It depends. From the pic it looks like there are support beams that connect both sides of the car together. If the roof is just a metal sheet then it could be just welded on top and structural integrity will be maintained.
Only way to know for sure is to take the roof off both cars and compare.
The roofs are different in structure and you would have to cut it at the pillars. Besides, if the roof had to be replaced for some reason, this is where they would probably do it. To skin the roof would be crazy. When the car it produced at the factory this is how the roof is put on, at the pillars.
