High beam assist bmw e60
My Ride: BMW e60 525Da LCI White, DPF out, Front grill black, Shadow line, license plate super bright led, interior white leds;
hi all i want to retrofit the fla mirror, but i want to know first what i need to buy, because a friend of mine have the mirror with fla but without the led, i have auto dim , sensor light and raind, the outside mirrors is auto dim, but i have to buy another sensor light and sensor or what, this is what i have
i have to change this sensor in picture??or just put another mirror and connect the cable in it?
I check in headliner and both wires blcak and yellow are connected to the mirror, why if i have not fla from factory?
The wires are black half white
The second wire is yellow with white?
My car is lci, you are sure that k-can wires are black and yellow, or are green and orange?because i heard that
Done it!for those don't know you have to remove the central trim of dashboard and then you will see a hole wich comes down in glove box
i will have to code the car to see if works, i keep update you guys!
Just completed this mod details online are very little and scattered everywhere so I'll add some helpful tips. If you have a late model e60 and your rain light sensor looks round instead of square shaped, pictured in first post. You will need to tap into kcan high (black) and kcan low (yellow) twisted wires. The closest place to locate them on the lci e60 is NOT in the rain sensor like most guides suggest, but connected to the kgm module located right below the glove box. You will need to remove the roof of the passenger side footwell, tap and splice into the yellow and black pins from the left most harness and route the wires up the right side pillar across the roof liner, into the sun roof controls and finally through the tube going to the mirror. you will need to source the proper tyco contacts to the wires and also source the proper 3 pin male harness to connect to the fla female harness on the mirror. Make sure you put black in pin one and yellow in pin 2 the third remains empty. Tuck everything away and put the car back together. Finally code it and all should be working correctly.
I will update further with some pictures and coding instructions soon ....
