Help with Umnitza V4 Installation
Old 05-14-2015, 10:27 AM
KingSoSa's Avatar
Default Help with Umnitza V4 Installation
Hey guys,
i finally got my umnitza v4 rings for my e60 lci.. so i started the pre install for testing the angel eyes but the rings did not light on after i touched the red and yellow wires to the plus battery terminal and the black wire on the grounding... what i made wrong?? Thank u for helping
Old 05-14-2015, 11:41 AM
Boost7's Avatar
My Ride: E60
Model Year: 2005
you have an LCI, just update the bulbs to something nice and bright, why bother with cutting into your headlights and resealing them.
Umnitza angel eyes = most expensive upgrades which yields nothing, brighter lights? smh
Old 05-15-2015, 11:35 PM
justalilbit's Avatar
My Ride: bmw
I don't think I could imagine a worse reply to this thread.
Old 05-16-2015, 07:43 AM
KingSoSa's Avatar
sorry but i dont want any other "bulbs" for my lci headllights.. my last bulbs were the lux v4 and i was frustrated about the result.. i love all these modded lci headlights with smd rings..
is there anybody who can help with the installation?? The pre install for testing to light up has succeeded.. the headlights i opened before.. but now i need help with the wiring.
Thank u and sorry for my bad english
Old 05-16-2015, 02:30 PM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Have you tried contacting Umnitza for help?
Old 05-16-2015, 02:44 PM
seven11's Avatar
My Ride: 535
i never understood why people would open up their E60 LCI headlights and put different halos, when they are much brighter than the pre LCI ones.
Until i got bulbs from umnitza and i am disappointed, the inner ring is much brighter than the outer one. at night the inner circle looks like a solid light, not a lit up halo and during the day you can't see the outer halo.
Now i understand why people go thru opening the headlights and do all that.
Old 05-16-2015, 03:00 PM
My Ride: bmw
While it's true the inner ring is brighter, it's likely you didn't install the bulb correctly. Most people don't properly line up the leds with the fiber optic tubes, resulting in the outer ring looking pretty dim.
Understandably, though. The bulb area is ridiculously cramped and a proper bulb install takes ~10 minutes just because of that.
Old 05-16-2015, 05:13 PM
Booyaazaa's Avatar
This is why I had mine opened up and V4's installed. Pic is in direct sunlight.
Old 05-16-2015, 05:17 PM
Booyaazaa's Avatar
It's not as simple as lining up the optic and smd led. It is the actual optic design that BMW uses that always makes the inner ring brighter then the outer rings. Even with HID upgrades, which I don't recommend, still have brighter inner rings then outer rings.
Old 05-17-2015, 07:26 AM
KingSoSa's Avatar
so guys,, i used the harness from a other led marker set with resistors... now my v4 are plug and play and without bc error the rings are so bright.. i love them
Attached Thumbnails Help with Umnitza V4 Installation-11009189_768567326589080_6139655929836249752_o.jpg   Help with Umnitza V4 Installation-11165249_768567366589076_7724521306080672258_n.jpg
Quick Reply: Help with Umnitza V4 Installation
