Help please new rims wont fit
Old Jul 14, 2013 | 11:57 AM
hernandezh12's Avatar
My Ride: 525i
Question Help please new rims wont fit
Hey,
So i recently bought some new rims for my 2004 525i but the wheel hubs on my car are exactly the same size as the holes in my rims, I was just wondering if i should just give up or if it's still possible to make them fit.
Old Jul 14, 2013 | 12:09 PM
aznfujikiddd's Avatar
My Ride: 535
Not sure what your question is?
Old Jul 14, 2013 | 03:30 PM
TLO03's Avatar
My Ride: alpine white 535 E61
Model Year: 08
If wheels are too big you may need hub centric rings... If too small you'd need a machine shop..
Old Jul 15, 2013 | 06:51 AM
Bobbrown13's Avatar
My Ride: 09 550i 6sp M-Tech. 18mm spacers rear, 8mm front. Dinan intake and Stage 2 tune. Tinted tails, M5 OEM lip spoiler. 08 Z4 3.0si Black on Black with Beige top. Removable hardtop. (Hers) 06 Volvo S60R Heavily Modded!! Gone and missed.
Originally Posted by hernandezh12
Hey,
Are you measuring to arrive at this conclusion? Are the rims new or used? Is there corrosion on either the hub or rim that needs to be cleaned. Get a wire brush or emory to clean them up if that is the case. If that's not it you will need to have the taper enlarged on the wheel or hub. A machine shop can take 0.003-0.004"" off the diameter and they should fit. Use some felpro neversieze to stop gauling. Too much clearance can give you vibration even tho our lug bolts are tapered.
BigxPx
May 30, 2015 07:51 AM
DILLESTJAMZ
May 5, 2015 12:56 PM
cmyachtie
Apr 30, 2015 04:17 PM
bestofthebest
Mar 30, 2015 08:12 PM
bananfiu
Mar 14, 2015 02:08 PM
