HELP PLEASE :(
I recently purchased a set of avus Mo-2 wheels, and the offset in the front is f@cked.... I am so pissed.. The wheels look great in the back, but the fronts sit in waaaaaaaaaaaay too much, i will post some pictures later. They are 20 inch wheels, so could someone please tell me the proper offset in the front? Avus is going to fix the wheels, and put new centers on, so i would really appreciate the proper offset. Could you also tell me the offset in teh back, so that I can make sure they didnt mess up there too. Nothing against AVUS, i love the wheels, they just dont fit correctly right now
THanks for all the help guys
Jer
Jer
If memory serves me right, the wheel offset for the E60 is 20mm all around unless you have a staggered set-up and then it changes somewhat in the rear. That's for OEM wheels so A-M wheels may be different. You'll get more help soon.
My Ride: 2006 550i M-Sport in Titanium Silver Metallic w/ HUD, Logic 7, iPod Interface, SAT, NAV, Style M-172 wheels
The proper offset should be 18mm all the way around unless you are going with a staggered set of wheels. If yours are staggered the usual 8.5" front and 9.5" rear, then the normal rear offset is 32mm. You can llikely push these numbers a couple of mm farther out, but much more than a couple of mm will result in rub unless you have your fenders rolled.
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
It would have helped if you had mentioned the width of the wheels, too, to get a proper answer. What size tyres are you intending to run and what is the width of the wheels ?
If I am right, it is a 255 tire in the front, and the rear is 285. The wheels are an inch wider than what is put on a stock M5 for both the front and the back. So the width in the rear is 10.5 and I think in the front is 9. I am going to post a picture so you can see what i am talking about. I really dont know much about how wheels are SUPPOSED to fit, I had an M3 before this M5, and when i got after market wheels they fit perfectly.
if you look at the picture, you will see the rears fit perfectly... but the front are messed.
Thanks for all the help
I assume you have the RWD model and not the xi? Update your signature, so we can help you further.
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Jer
Jer
