Help Installing DVD player
My Ride: 2013 535i xDrive AW/Black M-kit
I'm thinking of putting a DVD player inder the pass seat or somewhere near there. Im going to route the audio to the rear console aux port and potentially use the cigarette lighters back there. Would the cig lighter be "acc" because they're only on with the car? Then I could find a constant 12v wire and a ground? Any suggestions on placement so I'm not running wires all over? I want to make this an ez job.
I'm thinking of putting a DVD player in the glove box or somewhere near there.I need to tinder a gnu 12v and acc wire. Would a cigarette lighter be "acc" because they're only on with the car? Then I could find a constant 12v wire and a ground? Any suggestions on placement so I'm not running wires all over? I want to make this an ez job.
My Ride: 2007 LCI 535SE Auto,Mtech Bodykit and Rear Spoiler, Blufin Chipped, 124 alloys,Space grey, Folding Mirrors, Black leather, Adaptive headlights, Pro nav, Bluetooth,Logic 7,Comfort access, USB, Adaptive Cruise, Lane Departure, Acoustic Solutions DAB, love my car!
Retired-2003 530SE, 124 alloys,Titan silver, Black leather, Adaptive headlights, Business nav, Mtech Bodykit & Rear Spoiler,-petrol with LPG
Ciggerette lighter in cosule is probably best pick up for ignition switched supply- only problem is it does not stay on/come back on with the radio supply. If you want that, easyest pick up point is in boot, in fuse box. If you also want constant 12V, you can pick up easiest here too. Test whatever ccts you use- 1st when just turned off, then after 20-25 minutes, this ensures you are picking up both a switched and constant supply, as it takes roughly this long for car to enter sleep mode.
turbogate
04-11-2015 05:02 PM
