help hid in fogs not working
Old 04-20-2009, 11:27 AM
dr525i's Avatar
My Ride: 525i
hi guys. listen i just installed hid in my fogs yesterday,8000k. when i was installing them they work with no problem when the car was off just the key on the acc. but this kit i made it fit cuz i got them free. the problem is when the car starts the hids starts to blink off and on real quick like strobes lights. and i get the code fog light malfunction. only when the car is on it does it??? what do i need to do?? need help. thanks
Old 04-20-2009, 11:31 AM
acuteperformance's Avatar
My Ride: 14 550i
most likely won't work on your car then. you could try using some canceler cables but i couldn't guarantee they'd work. i believe i still have a few sets left if you want to try this route.
michael
acute performance
Old 04-20-2009, 11:40 AM
dr525i's Avatar
My Ride: 525i
michael
acute performance
what are those???? i was reading up on some other post. u think if i just some resistors it would stop this problem
Old 04-20-2009, 11:41 AM
dr525i's Avatar
My Ride: 525i
also i have a feeling it doin that cuz it not get 12v to the fogs when the car is on. can it be that?
My Ride: 14 550i
it's actually a capacitor. it might like i said i cant guarantee 100% it's just a suggestion.
michael
Old 04-20-2009, 12:09 PM
dr525i's Avatar
My Ride: 525i
michael
how much u selling this things for?
Old 04-20-2009, 01:32 PM
mag75's Avatar
What year is your car? If it is 2006 or greater, changing the fuse from 5 amps to 25 amps will solve this problem. Resistors will also work.
Old 04-20-2009, 01:34 PM
My Ride: 14 550i
try this first before buying from me. what fuse does he need to change? the fog light one?
Old 04-20-2009, 01:47 PM
dr525i's Avatar
My Ride: 525i
[quote name='mag75' date='Apr 20 2009, 05:32 PM' post='853158']
that suck my car is a 2005 u think it still work??
Old 04-20-2009, 02:02 PM
mag75's Avatar
I went through this problem with my 04. It happened a while back so I cant really remember the details all that great. Since yours is an 05, it might work
The fuse should be in your trunk (just above your battery comparment). Change fuse number 79. Change it from a 7.5 amp to a 25 amp (it also could be 81 or 82 it changes depending on the year and accessories options) which can be found in your bmw tool kit. If the strobing continues, just do trial and error. You cant mess up your car by using a larger amp.
Quick Reply: help hid in fogs not working
