help help help!!!!!!
quick question... All the wiring is correct. If I had the ground from one of the sides (passenger) grounded to the radiator cover, thats not the frame Huh??? could this have caused it to be a drain on the battery? And if so, where should I ground the passenger side? The driver side is grounded to the bolt that holds the struts.
Thanks
