Help! Active steering fault/inactive
My Ride: 2004 BMW e60 525i M-Sport
Fit some 20's to my 525i now I'm getting active steering fault, active steering inactive, drive control system fault. OBD2 cable came today hoping someone can help me out and this can be fixed with some coding?
Thanks in advance guys
Hmm try this:
Turn your car on all the way
Turn steering wheel all the way to the left
Turn it back all the way to the right
Turn it back to the center
Turn car off
Turn it back on and see if the error still appears
It's supposed to calibrate the steering angle sensor I think, but it cleared the active steering error when I had it.
Turn car off
Relax! The dealer will say its a $3,500 fix. new steering angle sensor and new active sway bars. Go to M5 board and look at the DIY section for active steering fix. Takes 45 min to take off the wheel and clean the optic lens in the wheel. Very easy to do.
Yeah the re-calibration didn't work. Ok thanks ill get onto it and check it out. Yeah dealers are rouges I know I used to work for one (not BMW) I'd rather stick in an aftermarket deck and texta over the fault light on the dash before handing money to them
Finally got around to doing this, wish i hadnt. Mine isn't the laser type it uses brushes I cleaned up the disc and put it all back together, no luck, and on top of that now my indicators arent shutting off on their own when you go around a corner :/ someone help please this is feeling like its going to get expensive
Did you read the whole DIY? You disconnected the battery, grounded yourself, and when reinstalling you did a full left to right to center? I have done 3 now and all have worked.
Followed the whole DIY for the E60, never said anything about grounding yourself, did you go off the DIY for the E90? Yeah did the recalibration afterwards, didnt work. Have the ones you've done been the Laser type like in the DIY, or the brush style like mine?
Went through and did it again, fixed the indicators but still have the active steering fault, have a fault code list from inpa if anyone could help translate would be great looked on the internet and couldnt find anything.
AFS: 6132 (70), 6139 (30), CE87 (71), CE9C (78)
DSC: 5F13 (E0), 5E85 (E0), 5E8A (E0), D368 (E4), D366 (E4), D369 (E4)
KLIMA: 9C54 (64), 9C55 (64), 9C77 (64)
Did a code scan with BMWhat this is the LOG file hoping someone can help me with where to start with this.
Fault Report - BMWhat - Version: 4.50
ID1: 55ceaf62-2df5-4dc5-9099-e70bbd5dacd9-879
ID2: af402cd1-b59f-4576-b64e-f6c95ed9654b-e9c
Base: E60 E61
Faults: 21
ECUs: 24
Model: get model info from car
Battery: no battery info
Normal communication
Normal connection
C 2
Date: 2013-09-23 23:56:56
USB Device
Version: 15
Device: >samsung< >m0xx< >GT-I9300<
Motor Control:
Engine / Motor
ECU OK, no Fault Code
ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung
ECU not present/no response from ECU
Dynamische Stabilitaets Kontrolle / DSC
Fehler: CAN error message / PT CAN fault / unknown failure
Code: D368
Fehler: CAN error message / CAN fault
Code: 5E89
Fehler: CAN error message / F CAN fault
Code: 5E8B
Code: D369
Code: 5E85
Fehler: CAN error message / CAN message / CAN fault
Code: D366
Airbag:
Advanced Crash and Safety Management (ACSM)
Fehler: Satellite driver's side B-pillar Y / MRSA-B Y left / Module disabled / Left column Y-direction / Servotronic Current invalid AFS
Code: 93CC
Fehler: Satellite B-pillar passenger side of Y / ECO-rated current invalid AFS / Module disabled / Y pillar right direction / MRSA-B Y right
Code: 93CD
Satellite front left door / Tuer vorne links
Satellite front right door / Tuer vorne rechts
Satellite B-pillar left / B-Saeule links
Satellite B-pillar right / B-Saeule rechts
Satellite center / Mitte
Transmission Control:
Transmission / Getriebe GS 19
Transmission / Getriebesteuerung
Instrument cluster:
Instrument cluster / Kombiinstrument
Central info display / Zentrales Display
Head-Up Display
Light/Rain Control:
Light / Licht
Rain/light sensor / Regen-Lichtsensor RLS
Light / Licht
High-beam / Fernlichtassistent
Heating / AC:
Air conditioning / Klimaanlage
Fehler: Short circuit to positive or open circuit (AUC) / Auto addressing failed automatic addressing (Lin) / unknown failure / Motor right rear stratification
Code: 9C54
Fehler: Error fogging sensor - K-LIN 3 RLS / PTC auxiliary heaters / Fresh air motor
Code: 9C55
Fehler: Short circuit to positive or open circuit - additional water pump / Refrigerant compressors
Code: 9C77
Additional heater / Zusatzheizung
Immobilizer System:
CAS
Park distance control:
Park Distance Control / PDC
Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung
Sunroof / Roof:
Sunroof / Schiebedach
Audio/Navi/Communication:
Multimedia-Changer / Wechsler
Speech recognition / Spracherkennungs-system
Phone / Telefon
Hifi Amplifier / Verstaerker
Tuner Antenna / Antenne
Hybrid Radio USA
Digital Satellite-Tuner USA
Headphones / Kopfhoerer Schnittstelle
Navigation
CD-Changer / Wechsler
Audio-System
Video
DAB
Seats:
Backrest width / Lehnenbreiteverstellung
Seats / Sitze
Seats / Sitze
Systems:
Gateway
Steering column switch / Lenkstockschalter
Fuel pump / Kraftstoffpumpe
Tire pressure control / Reifendruck Kontrolle
Passive Go System
Power Module
Night Vision
Flexible Bus-Interface / Schnittstelle
Car Communication Computer CCC
MASK
Center-Konsole
Night Vision Camera
Car Communication
Anti-theft alarm system:
Interior protection / Innenraumschutz
Theft alarm / Diebstahl Warnanlage
Chassis:
Air suspension / Luftfederung
Electronic damper / Elektronische Daempfer
Ergo-Commander
Body:
Automatisches Front Steering
Fehler: reference speed failure
Code: 6139
Fehler: monitoring missing / unknown failure
Code: 6145
Fehler: Communication errors F-CAN
Code: CE87
Fehler: Vehicle dynamics sensor 2 F-CAN / DSC-sensor 1 / Vehicle dynamics sensor 1
Code: CE94
Fehler: Vehicle dynamics sensor 1 F-CAN / Vehicle dynamics sensor 2 / DSC-sensor 2
Code: CE95
Fehler: Wheel speeds F-CAN
Code: CE96
Fehler: Steering wheel angle F-CAN / DSC sensor status / Steering wheel angle sum of angles
Code: CE97
Fehler: DSC control interventions F-CAN / Control interventions DSC AFS
Code: CE98
Fehler: Steering wheel angle F-CAN / Steering wheel angle above
Code: CE99
Fehler: Status DSC PT-CAN
Code: CE9C
Trailer / Anhaenger
Car Body Module
Tailgate / Hecktuer
Other:
Base: E60 E61
Faults: 21
ECUs: 24
Normal connection
C 2
USB Device
Version: 15
Motor Control:
Engine / Motor
ABS / DSC / Brake:
Code: D368
Code: 5E89
Code: 5E8B
Code: D369
Code: 5E85
Code: D366
Airbag:
Code: 93CC
Code: 93CD
Instrument cluster:
Head-Up Display
Light/Rain Control:
Light / Licht
Light / Licht
Heating / AC:
Code: 9C54
Code: 9C55
Code: 9C77
Immobilizer System:
CAS
Cruise Control:
Sunroof / Roof:
Phone / Telefon
Hybrid Radio USA
Navigation
Audio-System
Video
DAB
Seats:
Seats / Sitze
Seats / Sitze
Systems:
Gateway
Passive Go System
Power Module
Night Vision
MASK
Center-Konsole
Night Vision Camera
Car Communication
Chassis:
Ergo-Commander
Body:
Code: 6139
Code: 6145
Code: CE87
Code: CE94
Code: CE95
Code: CE96
Code: CE97
Code: CE98
Code: CE99
Code: CE9C
Trailer / Anhaenger
Car Body Module
Tailgate / Hecktuer
Other:
Check your Power Steering fluid level. No joke. All these systems run on CHF11S and if its starving fluid you can get weird codes. After that's checked, ensure you have run reinitialization on both AFS and ARS seperately and successfully
Vman33
03-14-2022 04:43 AM
Johnnywadd
09-03-2015 01:23 PM
