Heated seat stopped working! Help!
Hi guys,
Recently my heated seat button will not work, any ideas on a fix? I tried to check the fuse but that did not work...any other suggestions would be great..thanks! -Ant |
It could be the actual heat mat in the seat. You can swap the passenger wire connection at the switch to easily check this. If it's the actual mat then obviously the seat has to be disassembled and the leather removed to get to it. It's possible that the heat mat is sewn in, but I can't remember on this model.
