Headlights Replacement
Old Apr 25, 2021 | 07:59 AM
Johnny Tee's Avatar
My Ride: 2005 BMW 525i
Default Headlights Replacement
PLEASE HELP!!!
I recently purchased headlight assembly units off a 2004 BMW 525i to replace those on my 2005 BMW 525i. There are two issues:
~The 2004 has 2 plug-ins, the 2005 has 1.
~The 2004 main plug-in has 8 pins, the 2005 has 7.
What do I need to do to make this work??
2005 525i Headlight Assembly
2004 Headlight Assembly
Old Apr 25, 2021 | 02:32 PM
donpb's Avatar
My Ride: '06 530i N52
Is the new assembly the same exact P/N?
Old Apr 25, 2021 | 02:39 PM
Johnny Tee's Avatar
Yes
Old Apr 25, 2021 | 03:02 PM
Johnny Tee's Avatar
Old Apr 25, 2021 | 03:46 PM
donpb's Avatar
Ok, plug it in and see if it works. If it does, then great, if not, then return it. I'm not saying to fully install it, just plug it in.
Old Apr 25, 2021 | 04:00 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
They are not interchangeable. The one you have was replaced in 08/05 and stopped being put on cars after 02/05. For it to work it will cost you more time and money than it's worth. What is your build date?
Old Apr 30, 2021 | 05:19 AM
JeremyR's Avatar
My Ride: E60
Model Year: 2010
It looks like your car was equipped with Halogen headlights, and you are trying to swap it for a Xenon Headlight.
The 8 pin on the newer headlight is just an extra ground wire.
As seanjordan20 mentioned,
It would most likely require running about 6-8 new wires from the headlights to the cabin, plus a new headlight module, and AHL control module. They would also require some coding to the vehicles as well.
texasmr2
Feb 11, 2015 06:06 AM
JackThomas80
Jun 4, 2012 03:40 PM
itzstatic2k1
Nov 10, 2008 09:21 AM
itzstatic2k1
Sep 17, 2008 03:42 PM
