Headlights
My Ride: I HAVE A 2004 530I MOSTLY STOCK EXCEPT FOR 22IN ASANTI AF128 BLACK, I HAVE A 6 SPPED MANUAL TRANS. IT ALSO HAS DOOR CURTAINS WHICH I LIKE ALOT. NAVI. I HOPE TO CHANGE MY SEATS TO COMFORT SOON.
Hello all, i am wondering if anyone knows of a place that I can buy new headlight front plastic? Any help will be greatly appreciated
- You should be more specific why you are inquiring about (replacing) the clear plastic headlight covers, e.g.:
- Broken
- Pitted/scratched/frosted
- I strongly recommend you search the forum for (some) advice
- Purchase used replacements
- DIY fix for pitted/scratched plastic
The reason I wanted to know was I found a pair of lci headlights but both front plastic covers have a crack on them. When the lights do get opened what glue do ppl use. I read on the forum before that ppl where getting moisture inside from not using the correct adhesive glue. Any suggestions?
My Ride: 530i base model
Headlights have been a widely chatted topic on this forum.
- Broken
Sometimes when you can't find it you have to ask the questions, nothing wrong with that, I beleive that is what we are here for as a community.
I myself was wondering this as I know many folks out there have stuff laying around after doing retros, I used to find things like that when I had my Honda.
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
This is good info. Thanks for the post.
My Ride: 04 525i, 04 Dinan M3
Its hard to tell if that is surface scratches or if it runs deeper. You actually can buy the lenses on ebay at least but they are pricey and you still have to cut everything. If they are surface scratches that can easily be fixed like brand new. The thread I made yesterday goes over how to fix some of that. To me what that looks like is some sort of film over the headlight or clear that has cracked. Often times if people clear headlights its not done properly and it will crack like that. In fact when I did my nightshade this week I had the same effect on one side because the paint was not bonding to the plastic properly. I had to sand it to only 1000 grit(not 2000), and I didn't polish it either before applying and then did really light coats to start off. 99.5% of the time you won't need new lens you can restore them, the other small percentage where you do need to replace could be due to deeper gouges etc. But even then you may be able to use some plastic filler to keep it clear and restore.
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
umnitza
11-25-2015 11:10 AM
Bogdan7
09-23-2015 11:40 AM
