I'm looking to get front pads for a 2006 525i. I ran into these 2 part numbers
HB551F.748 http://www.empire1.net/racing/neonra...551f.748.shtml HB534.750 http://www.empire1.net/racing/neonra...534f.750.shtml What's the difference between the 2? the .750 seems to have a split between the pads. Is that any better or worse? |
551F.748 is the proper part number. Don't worry when you order I'll get you the proper set :)
balbs, order from Michael, he'll take care of you for sure. The Hawks have noticeable improvement in braking on my 545i.
p.s. He has an installer he can refer who I've used with no problems whatsoever.
So a buddy of mine works as a mechanic for Delta airlines (fixes their trucks, not planes). He was also a mechanic when he was in the army. Although he used to have an early 90's 3 series, he shouldn't have a problem changing brakes and rotors on an E60 right?
it's a piece of cake :)
Originally Posted by balbs
(Post 1205306)
(Post 1205306)
You can also try a DIY. |
Got my pads. Thanks Michael! What do you guys recommend for brake fluid?
dang it why didnt you tell me you needed this too :)
(Post 1206530)
Originally Posted by acuteperformance
(Post 1206542)
