has anybody retro fitted headlight washers?
need to know whats needed
i have standard headlights with no washer jets, is there a diy for this?
coding will be no problems, i just need to know what bits i need to buy and how to fit
orical's??
orical's??
coding will be no problems, i just need to know what bits i need to buy and how to fit??
BMW do a retrofit kit with all the bits you need for about ?155.00.
RealOEM will give you the part number. Pretty sure the kit includes a 5l tank to replace the 3l tank - make sense wouldn't it?
Instructions can be found here by doing a search.
The most time consuming bit seems to be removing bits to gain access to do the install and wiring.
Regards,
David
TexaZ3
05-06-2015 10:54 AM
