guys with oem m5 bumper upgrade
Guys,
Who have done the oem m5 bumper upgrade on your non M cars, what did you end up doing with the fig lights? Because you can use them with the OEM m5 bumper. Thanks in advance |
The M5 fenders are different/wider So the fitment from the oem m5 bumper to the non m5 fenders is not just a simple swap out and there is a little modification that needs to be done. I went with non oem m5 just for that reason.
Originally Posted by sachal007
(Post 1482181)
Guys,
Tony, i am also swapping the fenders :-)
Cwest, wouldn't having no bulb trigger some sort of warning light ? Can you bondo m5 reps fog housing on the OEM bumper? Thanks guys |
This is what I did. I taped the bulbs to the front frame:
http://i469.photobucket.com/albums/r...i/DSC02973.jpg - Antti - |
antti, i know its been a while but i am trying to find the list of all the parts you mentioned on your post, but i cant seem to find the post.
So far i have bought: M5 bumper M5 Fenders M5 Fender Liner Do i need to buy the brake ducts for the bumper and do you have the part #? |
You will also need:
- Support, side panel front left 51117895735 - Support, side panel front right 51117895736 - FRONT LEFT BRAKE AIR DUCT 51117895743 (only in conjunction with Bracket, air duct, left 51117906473) - FRONT RIGHT BRAKE AIR DUCT 51117895744 only in conjunction with Bracket, air duct, right 51117906474) - Antti - |
Originally Posted by Anzafin
(Post 1497394)
You will also need:
- Support, side panel front left 51117895735 - Support, side panel front right 51117895736 - FRONT LEFT BRAKE AIR DUCT 51117895743 (only in conjunction with Bracket, air duct, left 51117906473) - FRONT RIGHT BRAKE AIR DUCT 51117895744 only in conjunction with Bracket, air duct, right 51117906474) - Antti - antti, do i need the brackets? |
You mean these: 51117906473 and 51117906474?
If I remember it right, they are different in non-M5. The M5 bumper air ducts are very different shaped and the new brackets are needed to hold them. They are very PITA to change (not a lot of space to work there). - Antti - |
