FSD/Eibach Question for 550
So I've installed the Koni FSD/Eibach combination for my 07 550. Have a quick question, wondering if anyone has ran into this issue. This was installed several months ago and recently I had 3-4 people in the car and it was bottoming out horribly. Doing 70mph on freeways, the front & rear bottoms out over expansion joints/overpasses. Bottom of the car doesn't have scrape marks either. Didnt see any instructions in the box either. I verified the part #'s on the box and I did get the set for the 550. Tirerack said I can just return it, but I do like this alot ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Anyone have pointers? Thanks
My Ride: 5series
hmm...
Same thing happened to me today when I was on the highway my car bottomed out on the expansion joints entering and exiting the bridge, also I am trying to replace my shocks and want the FSD's how do you like them, btw will this work with h&r sports since the eibachs are only a little different, thanks
Originally Posted by peter@vmrwheels' post='771893' date='Jan 19 2009, 03:57 PM
Just 19's, with proper offset. After all, I make wheels ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Not sure if this is a spring rate, bumpstop, or fsd issue.
It is probably the shocks. If you can increase the stiffness of the shocks I would do that first. If you can't thats where I would guess the issue is coming from.
Anyone have pointers? Thanks![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I was considering the FSD's after reading so many good things about them but I don't plan on lowering my car. I have already scraped over some speed bumps and road imperfections at 2-5 MPH.
Make sure the struts are not leaking, also make sure tire pressure is enough for the people you have in the car. Give Koni tech line a call and see what they say
Peter,
The real solution here is to tell your friends to stop eating so much
With that said, I've never had a customer complain about bottoming out with this setup, maybe you need a set of bump stops?
Do you use any bump stop? If you do then bottoming out you mean as it hit the bump stop? Maybe you just need to trim the bump stop.
